Application guide: Local water stress test for extreme rainfall
This Application Guide describes how the Tygron Platform can be used to perform a local water stress test for extreme rainfall. It focuses on detailed analyses of neighbourhoods, urban districts, redevelopment areas and new developments.
The guide is intended for study areas in which local terrain, buildings, roads, sewer systems, surface water and water-storage measures can be represented in sufficient detail. It is not intended as a workflow for regional or upper-regional stress tests, where rainfall patterns, catchment-scale processes and the interaction between multiple water systems require a different modelling approach.
This guide bridges policy questions and Tygron functionality. It does not replace the technical documentation for the Rainfall Overlay, Water Overlay or Water Module.
Purpose
The purpose of this guide is to support users who want to answer the following question:
Where does waterlogging occur during extreme rainfall, and which areas, objects or routes are vulnerable?
Typical follow-up questions are:
  • Which streets or Neighborhoods are most vulnerable to waterlogging?
  • Which buildings are affected at a chosen water-depth threshold?
  • Which roads become difficult or unsafe to use?
  • Which vulnerable functions, such as schools, healthcare facilities or public buildings, are affected?
  • Which measures reduce waterlogging most effectively?
  • How do current and future design scenarios compare?
  • What data is needed for an extreme rainfall analysis?
  • How can results be prepared for a risk dialogue or decision-making process?
  • When is specialist hydraulic, sewer or groundwater software needed?
Target audience
This guide is intended for:
  • policy officers for climate adaptation;
  • municipalities;
  • water authorities;
  • provinces;
  • consultants;
  • GIS specialists;
  • urban planners;
  • hydrologists and modelers;
  • project leaders for public space;
  • stakeholders preparing risk dialogues or climate adaptation plans.
When to use Tygron
The Tygron Platform is useful for water stress tests when the goal is to analyse spatial vulnerabilities caused by extreme rainfall, compare scenarios and measures, and prepare results for decision making or stakeholder dialogue.
The Rainfall Overlay is the main Tygron component for this application. It is a Water Overlay connected to the Water Module. Users can start from the Demo Rainfall Project, follow How to work with the Demo Rainfall Project, or configure their own model using How to manually configure a Water Overlay and How to configure the Water Overlays.
Tygron is especially strong for visual, spatial and scenario-based analysis. It helps users understand where water accumulates, which areas are vulnerable, and how measures affect the situation.
Tygron is less suitable as a full replacement for specialist hydraulic, sewer or groundwater modelling software when detailed calibration, design calculations or formal engineering verification are required. In many projects, Tygron works best alongside specialist software.
Suitable use cases
This Application Guide is suitable for:
  • neighbourhood-level and district-level analyses of waterlogging;
  • water stress tests for existing urban areas;
  • redevelopment and new-development projects;
  • detailed analyses of water depth, duration and flow patterns;
  • assessing the impact of extreme rainfall on buildings, roads and vulnerable functions;
  • analysing the interaction between terrain, sewer systems, surface water and local storage measures;
  • comparing local rainfall scenarios and adaptation measures.
Less suitable use cases
Tygron is not suitable when the question mainly concerns:
  • multi-layered groundwater modelling;
  • hydraulic structure design;
  • static reporting without spatial analysis;
Example projects
The examples below show how the Tygron Platform has been used for local water stress tests in existing urban areas, redevelopment projects and new developments. The external project pages provide additional information about the project context, the analysis and the organisations involved.
Kronenburg-Uilenstede, Amstelveen
For the redevelopment of Kronenburg-Uilenstede, the proposed urban design was analysed in Tygron to assess the local water system and the effects of extreme rainfall. The model was also used to test design choices and adaptation measures, including floor levels, water storage and the routing of excess surface water.
Read the project description on the TAUW website: https://www.tauw.nl/projecten/watersysteemanalyse-kronenburg-uilenstede-amstelveen.html?utm_source=chatgpt.com
Stationsgebied Hilversum
For the redevelopment of the station area in Hilversum, Buro Regen&Water used Tygron to simulate rainfall events of 20 mm and 70 mm per hour. The analysis identified locations where waterlogging could occur and assessed the consequences for infrastructure, accessibility and the future spatial design.
Read the project description on the Buro Regen&Water website: https://www.buro-regen-en-water.nl/projecten/project-stationsgebiedhilversum
Ibisplantsoen, Amsterdam
For the redevelopment of the public space around Ibisplantsoen in Amsterdam, the preliminary design was assessed against a water-storage requirement of 70 mm of rainfall. QGIS and Tygron were used to simulate extreme rainfall and to test measures such as above-ground and underground storage, rain gardens and shell-based water buffers.
Read the project description on the Buro Regen&Water website: https://www.buro-regen-en-water.nl/projecten/project-IbisplantsoenTO
Vogeldorp, Amsterdam
For the existing residential neighbourhood of Vogeldorp in Amsterdam, Tygron simulations and AHN4 elevation data were used to create a map of rainfall-related bottlenecks for 276 homes. The study examined the sewer system, surface runoff and locations in the public space where waterlogging could occur.
Read the project description on the Buro Regen&Water website: https://buro-regen-en-water.nl/projecten/project-vogeldorp-modellering-openbare-ruimte.html
Schilderswijk and Noordpolder, Terneuzen
For the existing residential area of Schilderswijk and Noordpolder in Terneuzen, BOOT assessed a green-blue design in a Tygron digital twin according to the Zeeland climate label. Based on the simulation results, measures such as surface drainage channels towards water-storage facilities were added to the design. The plan is intended to prevent water from surrounding areas from flowing into the low-lying neighbourhood.
Read the project description on the BOOT website: https://www.buroboot.nl/project/klimaatrobuust-maken-van-de-schilderswijk-in-terneuzen/
De Nieuwe Stad, Amersfoort
For the transformation of De Nieuwe Stad in Amersfoort, BOOT created a water-on-street map for extreme rainfall. Tygron was used to compare the current and future situation and to assess measures including green roofs, infiltration crates, green strips and water-storage buffers.
Read the project description on the BOOT website: https://www.buroboot.nl/project/klimaatrobuuste-ontwikkeling-van-de-nieuwe-stad/
Analysis framework
A water stress test for extreme rainfall can contain several sub-analyses. These sub-analyses should not be treated as completely separate workflows when they are actually extensions of the same underlying analysis.
For this Application Guide, the recommended structure is to work with a limited set of main analyses and describe possible extensions underneath each main analysis. This prevents overlap between related topics such as impacted buildings, vulnerable functions, damage indication and critical infrastructure.
The main analyses are:
  1. Water depth and duration on the surface during extreme rainfall.
  2. Accessibility of critical routes for vehicles, such as cars, and bikes, but also pedestrians
  3. Impact on buildings.
  4. The availability after a rainfall event of water storage measures, such as wadis and blue-green measures.
Core question:
Where does water occur on the surface during extreme rainfall, how deep does it become, and how long does it remain there?
This is the central analysis for a water stress test. It shows where water accumulates, which locations are most exposed and how severe the calculated water depth is. From this analyses the other analyses can be derived:
The extensions include:
2. Accessibility and critical routes
Core question:
Which roads, routes or destinations become less accessible because of water on the surface?
This analysis combines water-depth and duration results with road data, critical routes or destination areas. It should include clear assumptions about which water-depth threshold is used for passability and for which road user this threshold applies.
Core question:
Which buildings, objects and functions are affected by water on the surface?
This analysis combines water-depth results with buildings, vulnerable functions and critical infrastructure. It is broader than a simple count of affected buildings. It can include regular buildings, critical buildings and vulnerable objects that may not be represented as standard buildings in the source data.
Core question:
How do wadis, storage facilities and blue-green measures function during and after the rainfall event?
This analysis focuses on the behaviour and reusability of local water-storage and infiltration facilities. It can be used both for existing facilities and for proposed climate adaptation measures.
Scenarios
A local water stress test should include multiple rainfall scenarios. The scenarios below are based on the Dutch DPRA standards for water stress tests and represent rainfall events with different intensities and durations.
The scenarios are used to identify where water accumulates, which buildings and roads may be affected and at which rainfall intensity parts of the local water system become limiting.
Rainfall scenario Duration Application in a local water stress test
70 mm 1 hour Used to analyse waterlogging during a severe short-duration rainfall event, with a focus on surface runoff, sewer-surface interaction, buildings and accessibility.
90 mm 1 hour Used to assess the same local system under a higher level of stress and to identify additional locations and functions that become affected.
155 mm 2 hours Used to assess a very extreme and longer-lasting rainfall event, in which the interaction between surface runoff, sewerage and surface water becomes increasingly important.
200 mm 48 hours Used to assess prolonged waterlogging under conditions in which the soil and surrounding surface-water system are also heavily loaded.
The DPRA provides the policy context, methodological background and further guidance for the use of these scenarios:
https://klimaatadaptatienederland.nl/stresstest/bijsluiter/bepalen-dreigingen/wateroverlast/
The detailed rainfall standards are described in:
https://klimaatadaptatienederland.nl/publish/pages/236276/geactualiseerde-notitie-standaarden-stresstest-wateroverlast-november-2024.pdf
Preferred data for detailed water stress analysis
This checklist can be used as a data intake specification when discussing data availability with a municipality, water authority or other data provider. It also helps connect commonly used Dutch data sources and project assumptions to the corresponding Tygron concepts.
With the setup of a project in Tygron there is always a datasource which can be used to do the analysis. This source is titled below as the Current starting point. There is also a preferred data source which gives a more detailed result of the analyses. There is also the issue of mapping the right attribute of the datasource to an attribute used by Tygron. For the default data this is already set up. But when a beter data sources is used the mapping is import. This attribute is given under the tile Required attributes
Elevation model
  • Why it matters: The elevation model strongly determines flow directions, local ponding, water depths, and the locations where waterlogging occurs. For most analyses, this is the most important data source.
  • Default Tygron data: The latest available AHN dataset.
  • Preferred data: Elevation measurements with a higher resolution than the AHN, preferably 0.5 m × 0.5 m or better.
  • Required attributes or values:
    • An elevation value for each raster cell in m relative to datum.
  • File format: GeoTIFF.
Surface water level
  • Why it matters: The surface water level determines the available storage capacity in open water, as well as the transportation of water through the model.
  • Default Tygron data: By default, the water level is set to 0.
  • Preferred data: Water level areas provided by the relevant water authority, usually this is the waterboard.
  • Preferred file format: Polygon geometry in GeoJSON or GeoPackage format.
Culverts
  • Why it matters: culverts determine hydraulic connectivity under roads, embankments and other barriers between waterways. Missing or incorrect culverts can strongly affect local ponding and flow paths.
  • Default Tygron data: IMWA.
  • Preferred data: municipal and water authority dataset with culvert information. Depending on the waterboard the HyDamo dataset is in principal a better source.
  • Preferred file format: spatial dataset, preferably GeoJSON or GeoPackage.
Weirs
  • Why it matters: weirs control overflow between water areas and can influence water levels, storage and discharge during and after rainfall.
  • Preferred data: Preferred data: municipal and water authority dataset with weir information. Depending on the waterboard the HyDamo dataset is in principal a better source.
Sewer areas and sewer outflow
  • Why it matters: sewer storage determines how much rainfall can temporarily be stored below ground. Sewer outflow represents water that leaves the model through the sewer system. The storage in mm multiplied by the sewer area surface gives the available storage volume in m³.
  • Default Tygron data: none, but a sewer can be generated based on the default urbanization factor of a neighborhood.
  • Preferred data: municipal dataset with sewer area information. There is a national dataset called GWSW which is in development and it depends on the municipality how usauble this dataset is.
    • sewer storage for stormwater, in m, per sewer area SEWER_STORAGE;
    • sewer outflow, in m³/s, from the sewer system SEWER_PUMP_SPEED;
    • geometry of each sewer area.
  • Preferred file format: polygon dataset, preferably GeoJSON or GeoPackage.
Sewer overflows
  • Why it matters: sewer overflows determine where stored sewer water can return to the surface or connect to the water system. This can be important during rainfall events.
  • Default Tygron data:: none.
  • Preferred data: municipal dataset with sewer overflow information.
    • location where stormwater overflows from the sewer system. The area cannot overlap with another sewer overflow area.;
    • the geometry of each sewer overflow must be located within the associated sewer area.
    • overflow height, in m relative to the applicable datum SEWER_OVERFLOW.;
    • overflow threshold, in m relative to the applicable datum SEWER_OVERFLOW_THRESHOLD;
    • maximum overflow discharge, in m³/s SEWER_OVERFLOW_SPEED.
  • Tygron term: Sewer overflow (Water Overlay).
Surface infiltration
  • Why it matters: surface infiltration determines how much rainfall can infiltrate into the ground before contributing to surface runoff or waterlogging.
  • Default Tygron data: Surface water can infiltrate into the unsaturated ground layer. It infiltrates at a speed defined by:
    • by the paved surfaces. The default dataset used is the BGT and the BAG;
    • the surface terrain's GROUND_INFILTRATION_MD attribute. The default dataset used is the BRO;
    • the ground terrain's GROUND_INFILTRATION_MD attribute. The default dataset used the BRO soil map;
  • Preferred data: soil investigations with infiltration measurements.
Ground percolation
  • Why it matters: percolation influences how much water can move from the surface and unsaturated zone to saturated zone. The initial saturation assumption can strongly affect the available storage for infiltrating rainwater.
  • Default Tygron data: Infiltrated water can percolate through the unsaturated ground layer. It uses by default the setting Infiltration only (in the rainfall overlay the attribute GROUND_WATER is set to 2). Therefore the groundwater level does not need to be sed and is NOT used in the calculation. Instead the maximum amount of water that can infiltrate is used MAX_INFILTRATION_M with a default of 1 meter of water storage [m3/m2].
    • It flows at a speed defined by he ground terrain's GROUND_INFILTRATION_MD attribute. The default dataset used the BRO soil map;
    • The default saturation of the unsaturated zone is set to 0%.
    • The total amount of infiltration is set and NOT derived from the groundwater level.
  • Preferred data: soil permeability and soil saturation of the unsaturated zone.
Water storage constructions
  • Why it matters: water storage constructions can temporarily store rainfall and reduce local waterlogging. They can be relevant for both existing infrastructure and future adaptation measures.
  • Current starting point: none.
  • Preferred data: dataset with water storage constructions, such as a building with roof for storing water.
Wadis
  • Why it matters: wadis can store and infiltrate water, but may also have overflow or drainage structures. Depending on whether the water must remain inside the project area or may leave the project, an overflow or intake can be represented using a pump, inlet or outlet-like modelling approach.
  • Preferred data: specific information about the wadi or the infiltration construction
    • Wadi:
      • wadi location;
      • height map of the wadi in m relative to datum;
      • the surface terrain infiltration in m/day GROUND_INFILTRATION_MD ;
      • the underground terrain infiltration in m/day GROUND_INFILTRATION_MD;
      • construction related to the wadi:
        • Culvert
          • Culvert location;
          • Culvert diameter CULVERT_DIAMETER, or height CULVERT_RECTANGULAR_HEIGHT and width CULVERT_DIAMETER for rectangular culverts;
          • bottom height of the culvert CULVERT_THRESHOLD;
          • Manning value CULVERT_N.
        • Drainage
        • Outlet
          • Outlet location;
          • The maximum amount of water flowing into the model through this Outlet in m3/dag. A negative value means the building functions as an outlet, and water is removed from the hydrological model INLET_Q;
          • The maximum amount of water which can flow in or out through this Building in m3 INLET_CAPACITY;
          • If a lower threshold is set drain, water will only flow into the model through this inlet until the water level at the point of this Inlet is equal to or greater than the threshold LOWER_THRESHOLD;
          • If an upper threshold is set, water will only flow out of the model through this inlet until the water level at the point of this Inlet is equal to or less than the threshold UPPER_THRESHOLD.
        • Pump
          • Pump location
          • The flow rate at which water is pumped from the lower end-point to the higher end-point in m3/sec PUMP_Q;
          • The threshold in m relative to datum of the lower end-point of the pump. Water flows from the lower end-point to the higher end-point until the water level at the lower end-point has reached the threshold. If not selected, the Lower Threshold will be ignored as a mechanic LOWER_THRESHOLD;
          • The threshold in m relative to datum of the higher end-point of the pump. Water flows from the lower end-point to the higher end-point until the water level at the higher end-point has reached the threshold. If not selected, the Upper Threshold will be ignored as a mechanic UPPER_THRESHOLD;
          • The top down orientation geo angle of the pump (0-360°) PUMP_ANGLE;
          • The maximum amount of water in m3 which can flow in or out through this Pump INLET_CAPACITY;
  • Preferred file format: spatial dataset, preferably GeoJSON or GeoPackage. For the height of the wadi a GeoTiff.
    • Tygron terms: none
Buildings with a critical function
  • Why it matters: building data is needed to translate water-depth results into vulnerable functions and critical infrastructure impact.
BAG. Critical functions may be identified using schools, healthcare facilities and other vulnerable functions. A generic threshold height may be assumed, for example 0.1 m above ground level.
  • Preferred data: building dataset with critical functions and threshold information.
    • building location;
    • whether the building is critical infrastructure;
    • building function or vulnerability category;
    • threshold height for impact assessment.
  • Tygron terms:
Threshold for buildings to be impacted
  • Why it matters: A building is considered to be impacted by water when the surface water level adjacent to the building reaches a certain height.
  • Default Tygron data: The settings for the result type impacted buildings result are by default 0,1 m.
  • Preferred data: a building dataset with threshold information. For example:
    • Shops = 0,001 m
    • Buildings constructed before 2022 = 0.05 m
    • Buildings constructed from 2022 onwards = 0,02 m
  • Tygron terms:
Priority roads and accessibility
  • Why it matters: road data and accessibility thresholds are needed to analyse blocked roads, critical routes, emergency access and reachability during extreme rainfall.
  • Default Tygron data: none.
  • Preferred data: dataset with road categories giving information on the critical roads.
    • road location;
    • road category or priority class;
    • water-depth threshold for accessibility.
  • Preferred file format: line or polygon dataset, preferably GeoJSON or GeoPackage.
Data quality notes
When using this checklist, the following data quality aspects should be checked explicitly:
  • whether all spatial datasets use the correct coordinate reference system;
  • whether polygons, lines and points have valid geometry;
  • whether areas, such as sewer and water level areas, do not overlap;
  • whether each sewer area has a maximum of one sewer overflow;
  • whether culverts, weirs, pumps and inlets have plausible orientation and height attributes;
  • whether all heights use the same vertical reference, for example m NAP;
  • whether units are in the same unit system;
  • whether default assumptions are clearly separated from measured or supplied data;
  • whether missing data has been replaced by assumptions, proxies or simplified representations;
  • whether local experts have reviewed the data before results are interpreted.
Hydrological initial conditions
The hydrological initial conditions describe the state of the water system at the start of the simulation. These conditions influence how much rainfall can initially be stored, infiltrated or discharged before water begins to accumulate on the surface.
For a local water stress test, the municipality and the water authority should jointly determine the initial conditions. The selected values should represent a plausible unfavourable situation and should be documented together with the model results.
The following initial conditions require an explicit choice:
  • the initial water levels in watercourses and other surface-water bodies;
  • the initial saturation and available storage of the unsaturated zone;
  • the initial groundwater level.
Initial surface-water levels
Initial water levels in watercourses are relevant for all rainfall scenarios.
The water level determines how much storage is available in the surface-water system and whether water from the urban area can be discharged into surrounding watercourses. A high initial water level reduces the available storage and may limit discharge from sewer outlets, overflows, drainage systems and surface-flow routes.
The initial water levels should be determined in consultation with the water authority. As a conservative starting point, use a relatively high but realistic water level:
  • for a controlled water-level area, use the summer level or another agreed high target level;
  • for an uncontrolled or freely draining area, use a water level associated with a high groundwater for example a level consistent with the Mean Highest Groundwater Level (GHG).
Unsaturated-zone storage
For the short-duration scenarios of 70 mm, 90 mm and 155 mm, the initial saturation of the unsaturated zone is not important in a local urban water stress test. These scenarios are dominated by high rainfall intensity, runoff over paved surfaces and interaction between the surface, sewer system and surface water.
The storage condition of the unsaturated zone should therefore be assessed explicitly for the 200 mm in 48 hours scenario. During this prolonged rainfall event, infiltration and the progressive filling of the soil can have a substantial effect on runoff and waterlogging.
For the 200 mm scenario, this Application Guide recommends the following default assumptions:
  • initial saturation of the unsaturated zone: 80%;
  • total thickness of the unsaturated zone: the difference between ground level and the initial groundwater level;
The geometrical thickness of the unsaturated zone is calculated as:
Unsaturated-zone thickness = ground level − initial groundwater level
This thickness is not itself the volume of water that can be stored. The actual water-storage capacity also depends on soil properties, particularly porosity and the relationship between water content and pressure head. When detailed soil parameters are available, these should be used to calculate the effective storage capacity.
Initial groundwater level
The groundwater level determines the thickness of the unsaturated zone and therefore influences the amount of water that can potentially be stored in the soil above the groundwater table.
Groundwater flow itself is not considered relevant for this analysis. The groundwater level therefore only needs to be represented as an initial boundary for calculating the thickness and available storage capacity of the unsaturated zone.
Required agreement and documentation
Before running the scenarios, the municipality and the water authority should agree on:
Initial condition Applicable scenarios Recommended starting point Purpose in the analysis
Initial surface-water levels 70, 90, 155 and 200 mm Use a relatively high but realistic water level, determined in consultation with the water authority. For controlled water-level areas, use the summer level or another agreed high target level. For uncontrolled or freely draining areas, use a water level associated with high groundwater conditions, for example a level consistent with the Mean Highest Groundwater Level (GHG). Determines the available storage in watercourses and the ability of the urban area to discharge water to the surrounding surface-water system.
Initial saturation of the unsaturated zone 200 mm in 48 hours Use an initial saturation of 80%. Determines how much additional rainfall can be stored in the soil during the prolonged rainfall event.
Initial groundwater level 200 mm in 48 hours Use a high but realistic groundwater level, preferably based on the GHG or another locally representative high groundwater level. Calculate the thickness of the unsaturated zone as ground level minus the initial groundwater level. Defines the lower boundary and thickness of the unsaturated zone. Groundwater flow itself does not need to be modelled for this analysis.
The selected values should be recorded for every model run. This is essential because different initial water levels or groundwater conditions can produce different water depths and durations, even when the same rainfall event is applied.
More information about initial conditions in Dutch water stress tests is available in:
Updated memorandum on standards for water stress tests, November 2024:
Workflow
A water stress test for extreme rainfall can be built up in several workflow levels. The core workflow is the rainfall simulation itself. Additional workflows support data preparation, impact analysis, result processing and reusable templates.
Core workflow: configure and run a Rainfall Overlay
Use this workflow when the goal is to calculate water depth and waterlogging during an extreme rainfall event.
  1. Define the policy question and study area.
  2. Choose the rainfall event and simulation duration.
  3. Add a Rainfall Overlay.
  4. Use the Rainfall Overlay tutorial and Water Overlay Wizard to configure the water system.
  5. Check the elevation model, terrain roughness, water areas, sewer districts and hydraulic structures.
  6. Set relevant simulation settings, timeframes and result type.
  7. Run the calculation.
  8. Inspect maximum water depth and other relevant result types.
  9. Validate the results with known problem locations, expert judgement and system checks.
  10. Export maps or use results in follow-up analyses.
Recommended implementation links:
Example workflow: start from the Demo Rainfall Project
Use this workflow when a user first wants to understand the method before applying it to their own project.
  1. Open the Demo Rainfall Project.
  2. Follow How to work with the Demo Rainfall Project.
  3. Inspect the configured Rainfall Overlay.
  4. Review the input data, such as water level areas, weirs, culverts and sewer areas.
  5. Inspect the resulting water-depth maps.
  6. Use the project as a learning reference before configuring a new project.
Data workflow: add or prepare external spatial data
Use this workflow when required data is not yet available in the project, for example local sewer districts, vulnerable objects, water-system areas or custom boundaries.
  1. Check which data is missing for the analysis.
  2. Prepare data as WFS, GeoJSON, GeoPackage or another supported geodata route.
  3. Add the data to the project.
  4. Map the imported data to the correct Tygron object type or attribute.
  5. Check whether the data is spatially correct.
  6. Use the data in the Rainfall Overlay, Combo Overlay or impact analysis.
Relevant implementation links:
Impact workflow: calculate affected buildings or vulnerable functions
Use this workflow when water-depth results need to be translated into impact.
Examples:
  • buildings affected by more than 0.10 m water depth;
  • public buildings affected by a lower threshold;
  • road segments affected by more than 0.10 m water depth;
  • vulnerable objects intersecting waterlogging zones;
  • neighbourhoods with a high fraction of built area affected by inundation.
Steps:
  1. Select the relevant water-depth result.
  2. Select the relevant object category, such as buildings, roads or vulnerable locations.
  3. Define thresholds.
  4. Combine water-depth results with object attributes.
  5. Calculate statistics or classify objects.
  6. Check map output against statistics.
  7. Export results for reporting.
Result-processing workflow: combine multiple calculations into one result
Use this workflow when results from several overlays, scenarios, areas or timeframes must be combined.
Examples:
  • combining multiple limited-area calculations;
  • accumulating results across timeframes;
  • combining water depth with building vulnerability;
  • preparing one output map for reporting;
  • creating a reusable result layer for a template.
Advanced workflow: connect overlays using prequels
Use this workflow when the result of one overlay needs to be used as input for another overlay.
Examples:
  • using a processed result as input for a Combo Overlay;
  • chaining rainfall results into a follow-up analysis;
  • building reusable calculation chains for templates.
This is an advanced reusable workflow, not a first-step workflow for new users.
Practical How-to routes
The following How-to pages can be used to translate common user questions into practical Tygron workflows. They are grouped by the type of task a user is trying to perform.
Start with an example project
Use these pages when the user wants to understand the method before configuring their own project:
These pages are especially relevant for questions such as:
  • How do I start a water stress test in Tygron?
  • Is there an example project for rainfall analysis?
  • How can I learn how the Rainfall Overlay works?
  • How do I understand the basic setup of a Water Overlay?
Configure rainfall and simulation settings
Use these pages when the user needs to define the rainfall event, simulation duration or spatial rainfall pattern:
  • How do I set a simple rainfall event, such as 70 mm in 2 hours?
  • How do I use a custom rainfall event?
  • How do I model a local rain shower?
  • How do I set the simulation time for a rainfall calculation?
  • How do I inspect the initial conditions of a rainfall simulation?
  • How do I use timeframes in a Water Overlay?
  • Can rainfall be limited to part of the project area?
  • Can rainfall vary spatially within the project area?
Infiltration by default when a Rainfall overlay is created the simulation is set to be infiltration only (the attribute of the Rainfall Overlay GROUND_WATER is set to the value 2).
Add or prepare local spatial data
Use these pages when the user has local datasets, such as sewer areas, buildings, vulnerable objects, water areas or hydraulic structures:
  • What data do I need for a water stress test?
  • How do I import municipal data into Tygron?
  • How do I import a GeoPackage, WFS or ArcGIS Online layer?
  • How can I prepare reusable data imports for a template?
  • How can imported data be mapped to Tygron objects or attributes?
Add sewer data and sewer overflows
Use these pages when sewer storage, sewer outflow or sewer overflows are relevant for the rainfall analysis:
  • How do I include sewer storage in a rainfall model?
  • How do I import sewer areas?
  • How do I model sewer overflows?
  • What happens if sewer areas or sewer overflows are missing?
  • How should sewer areas and sewer overflows be represented in Tygron?
Add surface water and hydraulic structures
Use these pages when water areas, culverts, weirs, pumps or inlets influence the flow of water:
  • How do I add culverts or weirs to a Water Overlay?
  • How do hydraulic structures affect rainfall results?
  • How can I check where water flows through the project area?
  • Why does water accumulate in a certain location?
  • How do waterways and water levels affect extreme rainfall results?
Add groundwater or drainage assumptions
Use these pages when groundwater, drainage or initial groundwater conditions are relevant to the rainfall analysis:
  • Should groundwater be included in a water stress test?
  • How do I add a groundwater GeoTIFF?
  • How do I use default groundwater information?
  • How do I model drainage?
  • How do I define an initial groundwater situation?
Analyse impact on buildings, roads or vulnerable functions
Use these pages when water-depth results must be translated into impact:
  • How do I calculate affected buildings?
  • How do I combine water depth with building attributes?
  • How do I apply a water-depth threshold?
  • How do I create an impact map for vulnerable functions?
  • How do I analyse road accessibility during extreme rainfall?
  • How do I mask water-depth results below a threshold?
Analyse accessibility and critical routes
Use these pages when water-depth results need to be translated into accessibility, blocked roads or evacuation routes:
  • How do I calculate which routes are blocked by water?
  • How do I create evacuation routes that avoid flooded roads?
  • How do I combine water-depth thresholds with travel distance?
  • Are critical destinations still reachable during waterlogging?
  • How can water-depth results be used in accessibility analysis?
Combine results from multiple calculations
Use these pages when results from multiple overlays, timeframes, scenarios or calculation areas need to be combined:
  • How do I combine results from multiple rainfall calculations?
  • How do I combine different overlays into one result map?
  • How do I process multiple timeframes?
  • How do I create a reusable output layer?
  • How can results from limited-area calculations be merged?
Compare measures and future scenarios
Use these pages when the user wants to compare adaptation measures or future designs:
  • How do I compare the current situation and a future design?
  • How do I add climate adaptation measures?
  • How do I model terrain changes as a measure?
  • How do I edit a measure outside Tygron?
  • How can measures be used to compare waterlogging before and after adaptation?
Validate and inspect model behaviour
Use these pages when the user wants to check whether the model behaves plausibly:
  • How do I validate a rainfall model?
  • How do I check whether water flows in a plausible direction?
  • How do I inspect output values for hydraulic structures?
  • How do I understand water-system behaviour behind the map result?
  • How do I use the Hydrologic System Overview for plausibility checks?
Export results for GIS, reporting or communication
Use these pages when results need to be exported for further analysis, reporting or stakeholder communication:
  • How do I export water-depth maps?
  • How do I export results to GIS?
  • How do I share rainfall results through GeoShare?
  • How do I export affected buildings or other objects?
  • How do I export object attributes for reporting?
Expected outputs
Expected outputs should follow the analysis framework. A project does not need to produce every output. The relevant outputs depend on the policy question, available data, selected scenarios and intended use of the results.
Water depth during extreme rainfall
Expected outputs include:
  • water-depth maps;
  • maximum water-depth maps;
  • water-depth classes for viewers or reports;
  • hotspot maps for local waterlogging;
  • comparison maps between rainfall scenarios;
  • GIS exports for further analysis.
Water on the surface, duration and recovery time
  • duration maps;
  • maps showing where water remains after the rainfall event;
  • recovery-time classes;
  • statistics per neighbourhood, road, square, area or object category;
  • indication of locations where water remains for a long time;
  • input for maintenance, design or risk dialogue.
  • road accessibility maps;
  • blocked-road maps based on water-depth thresholds;
  • critical-route impact maps;
  • accessibility maps for emergency services or vulnerable destinations;
  • evacuation-route or travel-distance maps, when relevant;
  • tables or statistics showing affected routes or destinations.
Impact on buildings and vulnerable functions
  • impacted buildings;
  • impacted critical buildings;
  • impacted vulnerable functions;
  • impacted utility assets or critical objects, when data is available;
  • statistics per building type, function, neighbourhood or impact threshold;
  • maps that distinguish ordinary buildings, critical buildings and vulnerable functions;
  • input for prioritisation, communication and risk dialogue.
Wadis, storage facilities and blue-green measures
  • duration of water in or around wadis;
  • remaining water at the end of the simulation;
  • maximum water level or maximum water depth in storage areas;
  • indication of whether a storage facility is available again after a dry period;
  • comparison of existing and proposed blue-green measures;
  • locations where extra storage or infiltration may be useful.
Plans, measures and scenario comparison
  • comparison between current and future situations;
  • comparison between base scenario and measure scenario;
  • difference maps;
  • statistics per scenario or measure;
  • change in water depth;
  • change in duration;
  • change in affected buildings or vulnerable functions;
  • change in accessibility or blocked routes;
  • visual material for decision making.
Validation, uncertainty and model confidence
  • validation notes;
  • list of confirmed assumptions;
  • list of remaining uncertainties;
  • comparison with known waterlogging locations;
  • results of expert review;
  • data-quality issues;
  • backlog items for future improvement;
  • decision on whether the results are suitable for the intended use.
Relevant result and output links:
The Water stress (Indicator) can be used to summarize the flood resilience of built areas based on the fraction of built area that inundates beyond a configured threshold. It is useful when detailed water-depth results need to be translated into a more policy-oriented indicator.
Validation
Validation is essential before water stress test results are used for communication, decision making or measure selection.
Recommended validation checks:
  • Check known problem locations.
  • Compare results with municipal reports, complaints or field knowledge.
  • Review results with water managers and local experts.
  • Check whether water accumulates in plausible low-lying locations.
  • Check whether flow paths and ponding locations are influenced by bridges, culverts, road edges or elevation artefacts.
  • Check whether sewer areas, sewer outflow and sewer overflows behave plausibly.
  • Check whether water-depth maps and statistics tell the same story.
  • Check multiple thresholds, for example 0.05 m, 0.10 m and 0.20 m.
  • Compare current and future situations.
  • Test sensitivity to rainfall intensity, grid size and infiltration assumptions.
  • Decide whether specialist modelling or additional data collection is needed.
Validation with the Water Overlay Wizard
During model setup, the Water Overlay Wizard can be used as an initial technical validation step. It provides feedback on the configured water system, imported data and settings. Warnings and errors should be reviewed before interpreting model results.
Use this check for:
  • missing or inconsistent water-system data;
  • incorrectly configured water areas;
  • warnings in imported data;
  • incomplete sewer or hydraulic structure configuration;
  • settings that may prevent the water system from functioning as intended.
This is a configuration check, not a full validation of model results.
Validation with tracing and measurements
Tracing and measurements can be used to inspect model behaviour after running a Water Overlay. These workflows help users understand where water flows, which objects influence the result and whether calculated object values are plausible.
Use this check for:
  • tracing water through the project area;
  • checking whether flow paths are plausible;
  • inspecting water levels, discharge or other output attributes for hydraulic structures;
  • exporting measurement results for review or reporting.
Validation with the Hydrologic System Overview
The Hydrologic System Overview plugin can be used as an additional validation and plausibility workflow after running the Water Overlay. It installs a dashboard for analysing Water Overlay results and creates a dashboard instance for each Water Level Area identified by the Water Overlay.
For a water stress test, this is useful when the user wants to understand whether the hydrological behaviour of the model is plausible at water-system level, not only at map level.
Use the Hydrologic System Overview to check:
  • whether water level areas behave as expected;
  • whether inflow and outflow patterns are plausible;
  • whether water is stored, routed or discharged in a logical way;
  • whether hydraulic structures strongly influence the result;
  • whether the model behaviour explains surprising water-depth patterns;
  • whether a result should be trusted, refined or investigated further.
The Hydrologic System Overview should not replace expert judgement, field validation or comparison with measurements, but it can help users understand the internal hydrological behaviour behind the map output.
Reusable concepts
Reusable concepts for this theme include:
  • Why use scenarios?
  • Why use templates?
  • Why start with a clear policy question?
  • Why separate theme, analysis, data, assumptions and workflow?
  • Why validate before communicating results?
  • Why compare current and future situations?
  • Why define water-depth thresholds?
  • Why combine water-depth maps with buildings, roads and vulnerable objects?
  • Why distinguish exploratory analysis from design-level modelling?
  • How can model results be translated into policy choices?
Useful reference links:
Relevant Tygron components
Relevant Tygron components include:
Comparison with other software
Tygron is strong for:
  • spatial scenario exploration;
  • visualisation of waterlogging;
  • combining water results with spatial objects;
  • measure comparison;
  • stakeholder communication;
  • risk dialogue preparation;
  • fast iteration between current and future situations;
  • integration of water results with buildings, roads and other spatial datasets.
Specialist tools may be more suitable for:
  • detailed sewer design;
  • formal hydraulic calibration;
  • highly detailed 1D/2D sewer and surface-water interaction;
  • detailed groundwater modelling;
  • regulatory design verification;
  • operational flood forecasting.
A practical way to position Tygron:
  • Use Tygron when the main goal is spatial insight, scenario comparison and communication.
  • Use specialist modelling software when the main goal is formal design, calibration or regulatory verification.
  • Use both when quick spatial insight must be checked or refined with specialist modelling.
Useful background links:
External context and comparable use cases
This section provides external context for the application of Tygron to water stress testing, urban waterlogging and pluvial flooding. These links are not Tygron implementation pages. They help connect this Application Guide to broader policy, research and climate-adaptation terminology.
External links should be used selectively. They are useful when they clarify the broader application context, for example DPRA stress tests, climate adaptation, pluvial flooding, road accessibility or upper-regional rainfall events. Technical implementation steps should still primarily link to Tygron documentation and How-to pages.
DPRA climate stress tests and risk dialogue
The Dutch Delta Programme for Spatial Adaptation (DPRA) provides the broader policy context for climate stress testing in the Netherlands. Climate stress tests identify vulnerabilities for themes such as waterlogging, heat, drought and flooding. The results are intended to support risk dialogue and adaptation planning.
Relevant external links:
Relation to this Application Guide:
  • Extreme rainfall analysis in Tygron can support the waterlogging part of a climate stress test.
  • Tygron can help create spatial insight into water depth, affected buildings, road accessibility, vulnerable functions and possible adaptation measures.
  • Tygron results can be used as input for stakeholder dialogue, risk dialogue and decision-making, provided assumptions and limitations are documented.
Useful terminology:
  • climate stress test;
  • waterlogging;
  • extreme rainfall;
  • vulnerability;
  • risk dialogue;
  • adaptation planning;
  • implementation agenda.
Water depth after short-duration heavy rainfall
The Dutch climate adaptation portal describes water depth after short-duration heavy rainfall as a relevant stress-test indicator. This focuses on water depth on streets and squares after intense rainfall. In sloping areas, flow velocity can also be relevant because high surface-flow velocities can create additional safety risks.
Relevant external link:
  • This is one of the closest external equivalents to the Tygron use case for extreme rainfall.
  • The primary Tygron output is a water-depth map, for example through the Rainfall Overlay and Water stress result type (Water Overlay).
  • For sloping areas or flow-path questions, this guide may connect to a separate Application Guide about surface runoff pathways or flow paths.
Useful terminology:
  • water depth;
  • short-duration heavy rainfall;
  • pluvial flooding;
  • surface runoff;
  • flow velocity;
  • streets and squares;
  • local waterlogging.
Klimaateffectatlas water-depth maps
The Dutch Climate Impact Atlas contains national maps for water depth after heavy rainfall events, including rainfall events such as 70 mm and 140 mm in 2 hours. These maps provide broad spatial insight and can be used as national reference context.
  • The Climate Impact Atlas provides national reference maps.
  • A Tygron project can provide a more local, scenario-based and data-specific analysis.
  • Tygron can include local elevation data, local sewer assumptions, surface water, hydraulic structures, vulnerable objects and local measures.
  • Differences between national maps and local Tygron results should be explained through differences in input data, assumptions, resolution and model setup.
Useful terminology:
  • national reference map;
  • local analysis;
  • water-depth map;
  • rainfall scenario;
  • scenario comparison;
  • local data.
Upper-regional stress tests for extreme rainfall
Upper-regional stress tests analyse large-scale extreme rainfall events that exceed municipal or regional boundaries. Deltares describes a national water image for large-scale extreme rainfall based on 200 mm in 48 hours. These analyses show expected water depth, duration of water on the surface and regional attention points.
  • A local Tygron water stress test and an upper-regional stress test have related but different purposes.
  • A local Tygron analysis is useful for detailed spatial insight, measure comparison and local decision support.
  • Upper-regional stress tests are useful for understanding broader system behaviour, regional disruption and cross-boundary effects.
  • Long-duration events, such as 200 mm in 48 hours, may require additional attention to groundwater, surface water, drainage, storage and regional discharge pathways.
Useful terminology:
  • upper-regional stress test;
  • large-scale extreme rainfall;
  • 200 mm in 48 hours;
  • water depth;
  • water duration;
  • regional disruption;
  • cross-boundary waterlogging.
Pluvial flood risk assessment in urban areas
The Copernicus Climate Change Service describes pluvial flood risk assessment in urban areas as a way to assess risks associated with extreme rainfall events in Europe. Pluvial flooding is flooding caused by intense rainfall that the ground and drainage system cannot absorb or discharge quickly enough.
  • This supports the use of the terms "pluvial flooding" and "urban waterlogging" in this guide.
  • The Tygron workflow fits the broader class of urban pluvial flood risk assessment.
  • The Tygron focus is practical scenario analysis, local spatial insight, impact analysis, measure comparison and communication.
Useful terminology:
  • pluvial flood risk;
  • urban flooding;
  • extreme rainfall;
  • risk assessment;
  • inundation;
  • exposure;
  • vulnerability;
  • adaptation measures.
Road accessibility and critical routes during waterlogging
Some waterlogging studies and stress-test datasets translate rainfall results into accessibility or passability of roads. This is relevant when water depth and water duration are combined with road networks, main access roads, emergency routes or critical destinations.
Relevant external context:
  • road passability during heavy rainfall;
  • water depth on roads;
  • duration of water on roads;
  • emergency access;
  • evacuation routes;
  • critical infrastructure;
  • road network disruption.
  • In Tygron, road accessibility can be analysed by combining rainfall results with roads and thresholds.
  • A Combo Overlay can classify flooded or blocked roads based on water-depth thresholds.
  • A Travel Distance Overlay can be used when the question concerns reachability, evacuation routes or access to critical destinations.
  • The threshold for passability should be documented as an assumption and should depend on the road user, such as pedestrians, passenger cars or emergency vehicles.
Relevant Tygron links:
High-resolution urban pluvial flood risk mapping
Research on urban pluvial flood risk often combines high-resolution elevation data, rainfall scenarios, building data, vulnerability information and impact indicators. This is similar to the structure of a detailed Tygron water stress test.
  • high-resolution elevation model;
  • surface runoff;
  • water-depth map;
  • affected buildings;
  • vulnerable functions;
  • exposure;
  • local impact assessment.
  • The quality of the elevation model strongly affects water depth and flow paths.
  • Building data and critical-function attributes help translate water-depth results into impact.
  • Impact thresholds should be documented, because they determine which buildings, roads or objects are counted as affected.
  • High-resolution local data generally increases confidence, but validation with local knowledge remains necessary.
Data-scarce pluvial flood modelling
In many urban waterlogging analyses, detailed sewer, drainage or infiltration data is incomplete. In such cases, simplified assumptions are used. This is acceptable for exploratory or planning-level analysis, provided the assumptions and limitations are documented.
  • data-scarce urban flood modelling;
  • simplified drainage representation;
  • rainfall uncertainty;
  • sewer storage assumptions;
  • infiltration assumptions;
  • uncertainty and limitations.
  • Tygron can be used for exploratory spatial analysis when not all specialist data is available.
  • Missing local data can be replaced by default data, national datasets, typology-based assumptions or simplified representations.
  • Reduced confidence should be stated clearly.
  • Detailed sewer design, formal calibration or legal verification may still require specialist hydraulic or sewer modelling software.
External links are useful for large language models when they provide context that is not specific to Tygron but important for understanding the application domain.
Use external links for:
  • policy context, such as DPRA climate stress tests;
  • common terminology, such as pluvial flooding, urban waterlogging and risk dialogue;
  • reference rainfall scenarios, such as 70 mm in 2 hours or 200 mm in 48 hours;
  • comparison between local Tygron analyses and national or regional stress-test maps;
  • explaining why assumptions, validation and limitations matter.
Do not rely on external links for:
  • Tygron implementation steps;
  • Tygron attribute names;
  • Tygron model settings;
  • Tygron result types;
  • Tygron import or export workflows.
For implementation, prefer internal Tygron links such as:
A good pattern is:
  • use external links to explain the broader application context;
  • use Application Guides to connect the context to a Tygron workflow;
  • use Tygron How-to pages to explain implementation.
Search terms from comparable use cases
This Application Guide may also be relevant for users searching for:
  • DPRA climate stress test
  • standardized climate stress test
  • waterlogging stress test
  • pluvial flood risk assessment
  • urban waterlogging
  • water depth after heavy rainfall
  • water depth on streets and squares
  • 70 mm in 2 hours
  • 90 mm in 1 hour
  • risk dialogue
  • flood impact on buildings
  • road accessibility during waterlogging
  • critical routes during flooding
  • high-resolution pluvial flood mapping
  • data-scarce pluvial flood modelling
  • simplified sewer modelling
  • rainfall scenario analysis
Key terms from comparable use cases
  • DPRA
  • waterlogging
  • pluvial flooding
  • water depth
  • rainfall duration
  • water duration
  • flow velocity
  • surface runoff
  • passability
  • evacuation routes
  • risk dialogue
  • local water stress test
  • uncertainty
  • validation
Frequently asked questions
Can Tygron be used for a water stress test?
Yes. Tygron can be used to analyse waterlogging caused by extreme rainfall, especially when the goal is spatial insight, scenario comparison and communication. See the Rainfall Overlay, Rainfall Overlay tutorial, How to work with the Demo Rainfall Project and How to manually configure a Water Overlay.
Which overlay should be used?
The Rainfall Overlay is the main overlay for extreme rainfall and waterlogging. It is a Water Overlay connected to the Water Module. The broader configuration can be supported by the Water Overlay Wizard, How to configure the Water Overlays and Basic water model use case (Water Overlay).
What data is needed?
The most important data are elevation, land use, buildings, roads, water areas, sewer areas, hydraulic structures, infiltration assumptions and validation data. Local data can be imported using Import Geo data, Geo Data Wizard, How to import a GeoPackage file, How to import data from a WFS or How to import data from ArcGIS Online. See also How to work with the Demo Rainfall Project.
How can I use a custom rainfall event?
A custom rainfall event can be configured using Weather data and simulation time settings. Relevant pages are How to load in dynamic rain and simulation time (Water Overlay), How to set linear rain and simulation time (Water Overlay), Weather (Water Overlay), How to create a Rain area, Rain area (Water Overlay) and Limit rain (Water Overlay).
A simple rainfall event can be configured using How to set linear rain and simulation time (Water Overlay). For time-varying rainfall, use How to load in dynamic rain and simulation time (Water Overlay). Rainfall and total simulation time are part of the Weather (Water Overlay) configuration.
How can I inspect the starting conditions of a rainfall simulation?
Use How to add a timeframe for initial conditions of a simulation (Water Overlay), Timeframes (Water Overlay) and Timeframe times (Water Overlay) when the initial state of the Water Overlay needs to be inspected or validated.
Can Tygron calculate impacted buildings and vulnerable functions?
Yes. Water-depth results can be combined with building geometry, building attributes and separate object datasets to analyse affected buildings and vulnerable functions. This can include ordinary buildings, critical buildings, schools, healthcare facilities, public buildings, utility assets, pumping stations, electricity assets or other locally defined vulnerable objects. Relevant links are Water stress (Indicator), Combo Overlay, Combo Overlay tutorial, How to edit a Combo Overlay formula, How to use building attributes in a Combo Overlay, Critical infrastructure (Function Value) and Impact flood threshold m (Water Overlay).
Can Tygron calculate road accessibility?
Tygron can support road accessibility analysis by combining water-depth results with road data and threshold assumptions. The threshold should depend on the intended interpretation, such as pedestrians, passenger cars or emergency vehicles. Relevant pages include Combo Overlay tutorial, Combo Overlay with masking, Combo Overlay with distance filtering, How to edit a Combo Overlay formula, Travel Distance Overlay and How to add the Travel Distance Overlay.
Can Tygron analyse evacuation routes or blocked roads during waterlogging?
Yes. Water-depth results from a Rainfall Overlay can be combined with a Combo Overlay to identify blocked cells or roads. These results can then be used with the Travel Distance Overlay, How to create an evacuation routes overlay or How to create a flexible Travel Distance Overlay to analyse accessibility or evacuation routes.
Should impact on vital functions be a separate analysis?
Not necessarily. Impact on vital or vulnerable functions is usually best treated as part of "Impact on buildings and vulnerable functions" when the question is whether a building, object or function is affected by water on the surface. It becomes a separate analysis only when the project also analyses functional failure, cascade effects, service areas, asset-specific vulnerability or dependencies between functions.
How should sub-analyses be structured?
For extreme rainfall, it is usually better to work with a limited set of main analyses and describe extensions underneath them. For example, affected schools, healthcare facilities, utility assets and critical infrastructure can all be grouped under "Impact on buildings and vulnerable functions". Emergency access, evacuation routes and blocked roads can be grouped under "Accessibility and critical routes". This prevents overlap and makes the analysis structure easier to interpret.
Can Tygron compare measures?
Yes. Measures and future designs can be compared by running scenarios and comparing water-depth maps, indicators and impact statistics. See Scenario, Measure, Future Design, Measures tutorial, How to add and remove measures, How to add an Area to a Measure, How to add a Terrain Spatial to a Measure and How to edit a Measure with QGIS.
Can Tygron export results to GIS?
Yes. Water results can be exported for use in GIS workflows, reports or web viewers. See GeoTIFF Overlay, How to export a Grid Overlay as GeoTIFF, How to export a Grid Overlay as GeoJSON, How to export a Grid Overlay to the GeoShare and Export Geo data.
How reliable are the results?
Reliability depends on the elevation model, rainfall event, grid size, infiltration assumptions, sewer assumptions, water-system data and validation. Results should be checked with local knowledge, known problem locations and, where possible, measurements. Relevant pages include Water Overlay Wizard, Configuration Wizard, How to trace water through project area (Water Overlay), How to inspect object output attributes of an overlay using the measurement tool, How to export measurements and How to add the Hydrologic System Overview plugin.
Can Tygron replace specialist hydraulic or sewer software?
Not as a general statement. Tygron is best positioned as a spatial, scenario-based analysis and communication tool. Specialist software may still be required for detailed design, calibration or regulatory verification.
Where does the Hydrologic System Overview fit?
The Hydrologic System Overview plugin fits under validation and plausibility checking. It helps users understand the hydrological behaviour behind Water Overlay results, especially per Water Level Area. See How to add the Hydrologic System Overview plugin, Dashboard, Water level area (Water Overlay) and Water Overlay.
AI summary
Tygron can support water stress testing by helping users analyse spatial vulnerabilities caused by extreme rainfall, compare current and future scenarios, assess water depth, duration, accessibility, affected buildings, vulnerable functions, storage facilities, measures and uncertainty, and prepare results for decision making or stakeholder dialogue. The Rainfall Overlay and Water Module are the core components for calculating rainfall-driven waterlogging. The Water stress (Indicator) can translate water-depth results into a more policy-oriented assessment of built-area resilience.
A good workflow starts with a clear policy question, a defined study area, a chosen rainfall event, required data, preferred data quality, explicit assumptions and a clear analysis framework. Users can start from the Demo Rainfall Project and How to work with the Demo Rainfall Project, configure rainfall using How to load in dynamic rain and simulation time (Water Overlay), How to set linear rain and simulation time (Water Overlay) or How to create a Rain area, inspect timeframes using Timeframes (Water Overlay), add local data using Import Geo data and Geo Data Wizard, include sewer behaviour using How to add sewer data (Water Overlay) and How to import sewer overflows, calculate impact using Combo Overlay tutorial and How to use building attributes in a Combo Overlay, analyse accessibility using Travel Distance Overlay, compare measures using Measures tutorial, and export results using How to export a Grid Overlay as GeoTIFF or How to export a Grid Overlay as GeoJSON.
Results should be validated using known problem locations, expert judgement, configuration checks, tracing, measurements and, where useful, the Hydrologic System Overview plugin. Sub-analyses should be grouped logically: vulnerable functions are part of building and object impact, emergency access is part of accessibility, and damage indication is an extension of impact analysis when suitable thresholds are available. Tygron is strongest for spatial insight, scenario comparison and communication. Specialist hydraulic, sewer or groundwater software may still be needed for detailed calibration, design or formal verification.
Related application guides may include:
  • Rural Water: Flow Paths
  • Flooding: Rapid Flood Impact Analysis
  • Rural Water: Water System Analysis and Water Balance
  • Groundwater and Drought
  • Rainwater Retention
  • Sewer Interaction and Surface Waterlogging
  • Climate Adaptation Measures for Water
  • Accessibility and Critical Routes
  • Water Model Setup with HyDAMO
  • Calibration and Validation of Water Models
  • Hydraulic Structures and Network Connectivity
Useful related Tygron links:
Search terms
This page may be relevant for users searching for:
  • Can Tygron be used for a water stress test?
  • How do I analyse waterlogging in Tygron?
  • How do I configure a Rainfall Overlay?
  • What data do I need for extreme rainfall analysis?
  • What data should a municipality provide for a water stress test?
  • What is the preferred data quality for a Tygron water stress test?
  • How do I translate Dutch water datasets to Tygron Water Overlay concepts?
  • Can Tygron calculate water depth during heavy rainfall?
  • Can Tygron compare adaptation measures?
  • Can Tygron calculate impacted buildings?
  • Can Tygron calculate road accessibility during extreme rainfall?
  • Can Tygron export water-depth maps to GIS?
  • How do I validate a rainfall model in Tygron?
  • Can Tygron replace hydraulic modelling software?
  • How do I include sewer storage in a Tygron rainfall model?
  • How do I import sewer overflows in Tygron?
  • How do I use a custom rainfall event in Tygron?
  • How do I use a Rain area in Tygron?
  • How do I combine rainfall results with buildings or roads?
  • How do I use a Combo Overlay for water stress?
  • How do I export rainfall results as GeoTIFF?
  • How do I compare measures for waterlogging?
  • What sub-analyses are relevant for extreme rainfall in Tygron?
  • How should water stress test analyses be grouped?
  • Can Tygron analyse vulnerable functions during extreme rainfall?
  • Can Tygron analyse critical infrastructure during waterlogging?
  • Can Tygron analyse wadi recovery time?
  • Can Tygron compare blue-green measures for waterlogging?
  • Can Tygron validate waterlogging results with local knowledge?
  • How do I set linear rainfall in Tygron?
  • How do I set 70 mm rain in 2 hours in Tygron?
  • How do I use timeframes in a Tygron Water Overlay?
  • How do I inspect initial conditions in a rainfall simulation?
  • Can Tygron analyse evacuation routes during waterlogging?
  • Can Tygron analyse blocked roads during extreme rainfall?
  • How do I use the Travel Distance Overlay with waterlogging?
Key terms
