Terrain ground infiltration md (Water Overlay)
| Icon | Attribute | Unit | Layer | Range | Description |
GROUND_INFILTRATION_MD | m/day | Surface | 0.0 to 10.0 | The speed at which water can flow vertically from the surface to the unsaturated zone. |
GROUND_INFILTRATION_MD | m/day | Ground | 0.0 to 10.0 | The speed at which water can flow vertically from the unsaturated zone to the saturated zone. |
Based on the properties of the terrain, water may infiltrate into the ground water system.
The speed at which water can infiltrate from the surface to the unsaturated zone is dependent on the GROUND_INFILTRATION_MD of the ground terrain and either the GROUND_INFILTRATION_MD of a building in that location or, if no building is present, the GROUND_INFILTRATION_MD of the surface terrain. The grid cell uses the lowest of these two values. If this value is 0, water cannot infiltrate into the unsaturated zone.
The maximum amount of water which can be stored in the saturated zone is based on the WATER_STORAGE_PERCENTAGE of the ground terrain.
Ground flow, or horizontal infiltration, are dependent on the infiltration properties of the ground, unless an aquifer exists at the same location.
- Groundwater level reduction is inversely proportional to the WATER_STORAGE_PERCENTAGE.
- Ground infiltration md (Water Overlay)
- Groundwater level formula (Water Overlay)
- Infiltration model (Water Overlay)
- Surface infiltration formula (Water Overlay)
- Ground infiltration formula (Water Overlay)
- Ground model (Water Overlay)
