Data preparation
Why prepare data?
Preparing data is useful when you have datasets you often use in Tygron Platform projects. For example, the Province of Utrecht has created the MKP template in the Tygron Platform. This module consists of indicators and panels concerning different environmental topics. For their indicators and panels to work, they need to import multiple datasets into every new project they use the template. For such use cases, it can save a lot of time if you prepare these datasets once and then easily import them into every new project. Read below for some considerations on various topics and apply the ones useful for you. On this page, 'data' refers to vector data.
Text attributes
Since the Tygron Platform can only import numerical attributes, it might be convenient to already look at the data to see if there are any text values you want to use later on in the Tygron Platform. For example in an indicator or to show the value of different attributes in an overlay. If you would like to make use of these text attributes, do a mapping from text to numbers before importing the data.
Consider the following example: you have a dataset with the suitability of buildings for solar panels. The suitability is described in a text attribute with values such as: suitable, not suitable, very suitable etc. We would like to create an indicator in the Tygron Platform that calculates some statistics about this dataset per neighborhood. We therefore need to import this suitability attribute as a numerical value into the Tygron Platform. See below for the steps:
How to create a mapping from text to numerical attributes:
  1. Open the vector dataset in a GIS
  2. Open the attribute table and click on Edit
  3. Add a new field, give it a name and choose as data type Integer with length 1 (this can differ depending on the dataset and use case)
  4. Use the Field Calculator to define the mapping to update the newly created column with numerical values (see image for example)
  5. Import the data into the Tygron Platform and notice the new attribute and values are imported
Naming of features
Text attributes in the data can only be used for naming features in the Tygron Platform. Naming of data is done in step 6 of the Geo data wizard. In this step it is possible to choose an attribute value for naming each polygon. It is important to give each area a fitting name, so if you have a lot of areas imported it is easy to distinguish between them. Choosing an informative attribute for names provides more detail when users click on areas in an overlay.
Consider the following example: Suppose you have a dataset with measurement locations and values. A name could be for example the id of the measurements. However more informative would be to have the location and date of the measurements as a name for each measurement area. These are text values and can not be imported in the Tygron Platform as such. By using them as name they can still be used to provide information to the user. Since you can only choose one column for naming, consider (if needed) to concatenate multiple attribute values to one value per feature (in this use case the location and the datetime were concatenated).
Extra attributes
It also might be convenient to add an extra attribute to your data if you want to create indicators or panels. Consider the following use case: you want to create a panel that pops up when you build a windmill in an area that is not allowed. These areas where a windmill is not allowed are for example Natura2000 areas, quiet areas (stiltegebieden), buffer zones around pipes, residential areas etc. These are all different datasets that can be imported into the Tygron Platform. In the panel, a TQL query to check if there are any gridcells where there is a windmill that overlaps with one of these imported areas, will look something like this: SELECT_LOTPOLYGONS_WHERE_FUNCTION_IS_880_AND_AREA_WITH_ATTRIBUTE_IS_..... The dots indicate the name of a common attribute the different datasets have. Adding a common attribute name to each dataset simplifies creating the panel and performing the windmill building check. The value of the attribute will not matter, as long as it is not 0, because that would translate in the Tygron Platform to the area not having this attribute. It is only about the attribute name. See the steps below for an example of adding an attribute to a dataset:
How to add an extra attribute:
  4. Use the Field Calculator to update the new field with a value which is not 0
  5. Import the data into the Tygron Platform and proceed with making your panel
Colors
In the Tygron Platform every polygon gets a random color. This will be visible in the legend. In some cases, you may want all polygons in the same category to share the same color.
For example, if each house in a solar suitability dataset is a polygon, assigning the same color to polygons within the same suitability class improves readability. It is possible, after importing the data to manually change the color of one or multiple areas. However, if you use the same dataset for multiple projects, it is more convenient to prepare the data first.
A solution could be to merge the polygons of the same classes so you will end up with one big multi polygon of suitable houses, one big multi polygon of less suitable houses etc. However, you will then not have access anymore to the individual attributes of each house polygon, such as the possible amount of solar panels on the house. In this situation (and numerous others), it might be helpful to add a column to the data with the color code to use by the Tygron Platform. Read below for the steps:
How to add a color code to a dataset:
  3. Add a new field, named COLOR with datatype Integer and length 10
  4. In the Tygron Platform, Click on the Current tab and then Areas.
  5. Add a new area and click on the Attributes tab. Change the color of the area to colors you want to use for each category, and write down/copy these numerical color codes
  6. Go back to the GIS and use the field calculator to update the COLOR attribute with the color codes (without separators) for the corresponding categories
  7. Save the file and import the data
Data publishing
If possible, the best way to publish data for use in the Tygron Platform is as a WFS. A WFS is preferable because it allows users to import data using only a URL in the Geo data wizard. This URL can be saved in a Template Project and makes it easier for users to import the data, since they only have to select the right URL in the Geo data wizard and import the datasets they want to use. In a WFS, the data provider can publish multiple datasets which are already prepared to use in the Tygron Platform.
If a WFS is not possible, use a GeoShare folder accessible to all organizational Tygron Platform users. In the folder, the different prepared datasets, in GeoJSON format can be stored.
