Sewer overflow (Water Overlay)
Sewer overflows are points where water is moved from the sewer to the surface water system. A sewer overflow will allow water to flow through if the water level in the sewer exceeds the calculated threshold height (based on SEWER_OVERFLOW_THRESHOLD), and the water level in the sewer is higher than the surface water level at the location of the overflow. Water will then flow out of the sewer overflow in that sewer area.
A sewer overflow is a point-based building. It must intersect with a sewer area but does not need to intersect with an actual sewered building.
SEWER_OVERFLOW | m + datum | -10000 to 10000 | The height at which the Sewer Overflow is situated. The average height at which the related Sewer Area will be situated is relative to this height. | n/a |
SEWER_OVERFLOW_SPEED | m3/s | 0 to 3.4028235E38 | The maximum volume of water flowing through the overflow per second. | 10 |
- At most one overflow can be linked to a sewer area and vice versa.
- Water will flow from the sewer, through the sewer overflow, to open water when the water height in the sewer is larger than the calculated threshold height (see formula and threshold).
- Sewer overflows can be generated along with sewer areas in the configuration wizard. They will be generated in the first water terrain which is covered by a sewer area and a water area.
- Sewer Overflow formula (Water Overlay)
- Sewer overflow threshold (Water Overlay)
- Sewer area (Water Overlay)
- Sewer model on Sewer Overflow
