Pump upper threshold (Water Overlay)
This attribute can be defined as values over time, using an array of values defining start-time. This allows users to more dynamically define the target water level this pump maintains.
  • When the PUMP_Q of the pump is positive, the pump will not pump if the water level is higher than or equal to the upper threshold. If the PUMP_Q is negative, the pump will not pump if the water level is lower than or equal to the upper threshold.
  • When using a dynamic UPPER_THRESHOLD, a maximum of 10.000 values (5.000 pairs) can be defined.
API Endpoints
