Inlet area (Water Overlay)
INLET_AREA | boolean | 0 to 1 | When true the Inlet is spread across the entire building surface. | 0 |
- Selecting this option is useful when the INLET_Q value is too large for a single cell.
- The area works best when applied as a narrow strip.
- An inlet area always has one associated datum height. The selected height is the highest of all cells belonging to this area.
- On sloped terrain, this setting may prevent outlets from removing all water. It is therefore advised to disable this option and use center point outlets to remove water at the edge of your project. See How to use outlets to remove water on the edges of your project.
