Api session event editor overlay set key value
API Endpoint: api/session/event/editoroverlay/set_key_value/
Description: Set a key to an Attribute for a Grid Overlay
| 0 | REQUIRED | (OVERLAY Integer ID) | Grid Overlay | |
| 1 | REQUIRED | (String) | Key | |
| 2 | REQUIRED | (String) | Attribute |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_key_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Key", "Attribute" ]'JavaScript example POST
body: '[ 1, "Key", "Attribute" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_key_value/", options)
