Pump angle (Water Overlay)
The principle for a weir with an angle. The same principle is applied for a pump.
Adjustable in the pump step of a Water Overlay wizard
  • This angle is used to generate a line for the front and end points of the pump. Additionally, the elevation is also automatically adjusted for the region perpendicular to the pump angle.
  • If no angle is available as an attribute, the angle can be calculated by using the Generate Angles option in the Pumps step of the wizard.
  • A pump is not required to have an angle. As long as a center line can be derived from it's polygons, it can be placed.
  • This parameter does not influence the order in which water flows from one Water Level Area to another; A pump's flow direction is always from the Water Level Area with the lowest level, to the other (second lowest) water level area it intersects with.
API Endpoints
