Drainage q (Water Overlay)
DRAINAGE_Q | m3 per second | -3.4028235E38 to 3.4028235E38 | The maximum pump flow capacity, defined in cubic meters per second. | 1 |
This attribute can be defined as values over time, using an array of values defining interpolation-time. This allows users to dynamically define the drainage flow capacity over time.
- When using a dynamic DRAINAGE_Q, a maximum of 10.000 values (5.000 pairs) can be defined.
- Drainage (Water Overlay)
- Drainage formula (Water Overlay).
- Drainage active (Water Overlay)
- How to import a time sequence with a CSV
