Sewer overflow (Water Overlay)
Revision as of 12:13, 4 September 2026 by Frank@tygron.nl (talk | contribs)
Sewer overflows are points where water is moved from the sewer to the surface water system. A sewer overflow will allow water to flow through if the water level in the sewer exceeds the calculated threshold height (based on SEWER_OVERFLOW_THRESHOLD), and the water level in the sewer is higher than the surface water level at the location of the overflow. Water will then flow from all sewer overflows within that sewer area.
A sewer overflow is a point-based building. It must intersect with a sewer area but does not need to intersect with an actual sewered building.
  • Schematic overview of a sewer overflow.
  • Schematic overview of water overflowing from a sewer.
API Endpoints
