Api session event editor overlay
Revision as of 07:05, 14 July 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/
API endpoints for Overlay editing.
Name Description
add Add a new Overlay of the specified type.
append_attribute Appended to existing Overlay numeric Attribute value
duplicate Duplicate existing Overlay
remove Remove the specified Overlays.
remove_attribute Remove the specified Attributes of the specified Overlay. The Attributes, including Attributes which are added to an Overlay by default, are removed entirely.
set_attribute Set Overlay numeric Attribute value
set_attributes Set multiple Overlay numeric Attribute values
set_name Set the name for a specified Overlay.
Additional API endpoints:
Name Description
add_legend_entry Add a Legend Entry to a specified Overlay. The Overlay must have a custom legend before entries can be added to it.
add_overlay_function Add a highlighted Function to a specified Function Overlay.
add_result_child Add a specified Result type as a child Overlay to a specified Grid Overlay. The child Overlay's result will be based on the parent's calculation, allowing you to get multiple types of results from the same calculation.
add_type Add multiple new Overlays of the specified types.
remove_legend_entry Remove the specified legend entries from a specified Overlay. The Overlay must have a custom legend before entries can be removed from it.
remove_overlay_function Remove a highlighted Function from a specified Function_HIGHLIGHT Overlay.
remove_prequel Remove a Grid Overlay's prequel Overlay.
remove_water_weather Remove Water Weather
save_grid Create a copy of each specified Overlay. The copies will have the same Settings and Attributes, but can be edited independently of the originals.
set_attribute_overlay_color_attribute Set which Attribute a specified Attribute Overlay should use to color the Items it finds. If present in the Item, it will use that Attribute's color to color the Item in the 3D world. If absent, the Overlay's color will be used.
set_attribute_overlay_values Set which type of Item and which Attribute a specified Attribute Overlay should highlight. The Attribute Overlay will highlight each Item it finds which is both of the specified Map Type as well as has the specified Attribute
set_avg_distance Set the averaging distance for a specified AVG Overlay.
set_combo_formula Set formula for a Combo Overlay.
set_custom_legend Set whether the specified Overlay has a custom legend. If the specified Overlay is reverted to use a default Overlay, any custom legend information for the Overlay is removed.
set_discharge_method Set Discharge Method
set_geotiff Change the GeoTIFF displayed by a specified GeoTIFF Overlay.
set_grid_active Activates or deactivates an Overlay. Only active Overlays are recalculated by the Simulation.
set_heat_model Set Heat Model
set_image Change the icon displayed in the navigation window by the Overlay. Only existing Overlay Project Assets are allowed.
set_key_value Change a key for a specified Overlay. The Overlay must use keys to read geographical Item Attributes as calculation input.
set_legend_entry_color Change the color of a specified legend entry of a custom legend of a specified Overlay.
set_legend_entry_name Change the name of a specified legend entry of a custom legend of a specified Overlay.
set_legend_entry_value Change the value of a specified legend entry of a custom legend of a specified Overlay.
set_net_overlay Set the visualization style for a specified network Overlay.
set_neural_network Set the Neural Network for an Inference Overlay.
set_overlay_area Add or remove specified Areas to or from a specified Areas Overlay. Unincluded Areas which are already related to the Overlay will remain related. Unincluded Areas which are not related to the Overlay will remain unrelated.
set_overlay_image Change the image displayed by a specified IMAGE Overlay. The image must be uploaded in the "Overlays" directory.
set_overlay_primary_color Set the color a specified Function or Attribute Overlay uses to highlight found data.
set_overlay_remainder_color Set the color a specified Function or Attribute Overlay uses to color parts of the map where no relevant data is found.
set_overlay_source Add or remove specified Sources to or from a specified Source Overlay. Unincluded Sources which are already related to the Overlay will remain related. Unincluded Sources which are not related to the Overlay will remain unrelated.
set_parent Set a parent Overlay for a specified Overlay, making it a subselectable child. An Overlay with a parent cannot be assigned as a parent to another Overlay.
set_prequel Set prequel Overlay.
set_rasterization Set the type of rasterization a specified Average, Combo or Distance Overlay should perform.
set_result_type Set the Result type of a specified Grid Overlay. The same calculation will be performed, but a different aspect of the calculation will be tracked and output.
set_service_crs Set the preferred CRS for the Service Source of a specified Service Overlay.
set_service_force_xy Set the preferred option to force the CRS order to longitude/latitude for the Service Source of a specified Service Overlay.
set_service_layer Set the Service Layer names for a specified Service Overlay and Timeframe.
set_service_source Set the Service Source for a specified Service Overlay.
set_show_difference Set whether a specified Grid Overlay has a difference option. If an Overlay has a difference option, an addition output is available computed from the difference between the CURRENT and MAQUETTE outputs.
set_show_system_visualization Set whether a specified Overlay visualizes the graph of systems which dictates its calculation. Pipes, center Points of Areas, etc.
set_tensor_normalized Set whether an input tensor of an Inference Overlay should be normalized when provided to a Neural Network.
set_tensor_prequel Set the Inference Prequel for an input tensor of an Inference Overlay.
set_tensor_result_type Set the Inference Result for an output tensor of an Inference Overlay.
set_tensor_value_type Set the Value Type for an input tensor of an Inference Overlay.
set_visible Visualizes or hides an Overlay in the navigation Panel.
set_water_mode Set Water Mode
set_water_weather Set a specified Weather to serve as input for a specified water Overlay.
swap_order Swap Order
