Api session event editor overlay remove prequel
API Endpoint: api/session/event/editoroverlay/remove_prequel/
Description: Remove a Grid Overlay's prequel Overlay
0 REQUIRED (OVERLAY Integer ID) Grid Overlay
1 REQUIRED (String) Prequel Type Name
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove_prequel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Prequel Type Name" ]'
JavaScript example POST
 body: '[ 1, "Prequel Type Name" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/remove_prequel/", options)
