Api session event editor overlay remove attribute
API Endpoint: api/session/event/editoroverlay/remove_attribute/
Description: Remove the specified Attributes of the specified Overlay. The Attributes, including Attributes which are added to an Overlay by default, are removed entirely
0 REQUIRED (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) Overlays
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attributes to remove
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attributes to remove 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Attributes to remove 1", "Attributes to remove 2", "Attributes to remove 3" ] ]'
JavaScript example POST
 body: '[ 1, "Attributes to remove 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/remove_attribute/", options)
