Api session event editor overlay set tensor prequel
API Endpoint: api/session/event/editoroverlay/set_tensor_prequel/
Description: Set the Inference Prequel for an input tensor of an Inference Overlay
0 REQUIRED (OVERLAY Integer ID) Inference Overlay
1 REQUIRED (Integer number) Tensor Link ID
2 REQUIRED (String) Inference Prequel
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_tensor_prequel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Inference Prequel" ]'
JavaScript example POST
 body: '[ 1, 1, "Inference Prequel" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_tensor_prequel/", options)
