Api session event editor overlay set service layer
API Endpoint: api/session/event/editoroverlay/set_service_layer/
Description: Set the Service Layer names for a specified Service Overlay and Timeframe
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay (WMS or WCS) | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Layer names |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_service_layer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Layer name 1" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_service_layer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ "Layer name 1", "Layer name 2", "Layer name 3" ] ]'JavaScript example POST
body: '[ 1, "Layer name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_service_layer/", options)
