Api session event editor overlay set rasterization
API Endpoint: api/session/event/editoroverlay/set_rasterization/
Description: Set the type of rasterization used by a Average, Combo or Distance Overlay
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay (Average, Combo or Distance) | |
| 1 | REQUIRED | (Enumeration) | Rasterization type | FIRST, MAX, MIN, SINGLE_LAYER or GRID |
| 2 | OPTIONAL | (Enumeration) | Maplink (will only affect the SINGLE_Layer rasterization type): Buildings, Terrains, Areas, Neighborhoods |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_rasterization/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "FIRST" ]'JavaScript example POST
body: '[ 1, "FIRST" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_rasterization/", options)
