Api session event editor overlay remove
API Endpoint: api/session/event/editoroverlay/remove/
Description: Remove the specified Overlays
0 REQUIRED (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) Overlays
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/remove/", options)
