Api session event editor overlay set geotiff
API Endpoint: api/session/event/editoroverlay/set_geotiff/
Description: Set the GeoTIFF displayed by a specified GeoTIFF Overlay
| 0 | REQUIRED | (OVERLAY Integer ID) | GeoTIFF Overlay | |
| 1 | REQUIRED | (GEO_TIFF Integer ID or multiple integer values in array [1, 2, 3]) | GeoTIFFs |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_geotiff/", options)
