Api session event editor overlay set result type
API Endpoint: api/session/event/editoroverlay/set_result_type/
Description: Set the Result type of a Grid Overlay. The same calculation will be performed, but a different aspect of the calculation will be tracked and output.
0 REQUIRED (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) Grid Overlays
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Result type for the Overlay (must be a valid Result type of the Overlay type)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_result_type/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Result type for the Overlay 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_result_type/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Result type for the Overlay 1", "Result type for the Overlay 2", "Result type for the Overlay 3" ] ]'
JavaScript example POST
 body: '[ 1, "Result type for the Overlay 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_result_type/", options)
