Api session event editor overlay set heat model
API Endpoint: api/session/event/editoroverlay/set_heat_model/
Description: Set the Heat Model of a Heat Stress Overlay
| 0 | REQUIRED | (OVERLAY Integer ID) | Heat Stress Overlay | |
| 1 | REQUIRED | (Enumeration) | Heat Model | DPRA or UNESCO |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_heat_model/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "UNESCO" ]'JavaScript example POST
body: '[ 1, "UNESCO" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_heat_model/", options)
