Api session event editor overlay set water mode
API Endpoint: api/session/event/editoroverlay/set_water_mode/
Description: Set the Water Mode of a Water Overlay
0 REQUIRED (OVERLAY Integer ID) Water Overlay
1 REQUIRED (Enumeration) Water Mode ACCURACY, AVERAGE or SPEED
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_water_mode/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "SPEED" ]'
JavaScript example POST
 body: '[ 1, "SPEED" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_water_mode/", options)
