Api session event editor overlay add result child
API Endpoint: api/session/event/editoroverlay/add_result_child/
Description: Add a specified Result type as a Result Child Overlay to a Result Parent Overlay
0 REQUIRED (OVERLAY Integer ID) Result Parent Overlay
1 REQUIRED (String) Result type
200 Integer (Overlay ID)
curl 'https://engine.tygron.com/api/session/event/editoroverlay/add_result_child/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Result type" ]'
JavaScript example POST
 body: '[ 1, "Result type" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/add_result_child/", options)
