Api session event editor overlay set avg distance
API Endpoint: api/session/event/editoroverlay/set_avg_distance/
Description: Set the averaging distance for an Average Overlay
| 0 | REQUIRED | (OVERLAY Integer ID) | Avg Overlay | |
| 1 | REQUIRED | (Floating point number) | Averaging distance |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_avg_distance/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 37 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_avg_distance/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 92 ]'JavaScript example POST
body: '[ 1, 37 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_avg_distance/", options)
