Api session event editor overlay save grid
API Endpoint: api/session/event/editoroverlay/save_grid/
Description: Create a deactivated copy of each specified Overlay
0 REQUIRED (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) Overlays
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/save_grid/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/save_grid/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/save_grid/", options)
