Api session event editor overlay set parent
API Endpoint: api/session/event/editoroverlay/set_parent/
Description: Set a parent Overlay for an Overlay. An Overlay with a parent cannot be assigned as a parent to another Overlay
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay | |
| 1 | REQUIRED | (Integer number) | Parent Overlay |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_parent/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_parent/", options)
