Api session event editor overlay set show system visualization
API Endpoint: api/session/event/editoroverlay/set_show_system_visualization/
Description: Set whether a Water Overlay visualizes the graph of systems which dictates its calculation. Pipes, center Points of Areas, etc
0 REQUIRED (OVERLAY Integer ID) Water Overlay
1 REQUIRED (Enumeration) Water System AREAS or OBJECTS
2 REQUIRED (true, false) Visualized true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_show_system_visualization/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "OBJECTS", true ]'
JavaScript example POST
 body: '[ 1, "OBJECTS", true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_show_system_visualization/", options)
