Average Overlay
Revision as of 07:38, 10 July 2026 by Frank@tygron.nl (talk | contribs)
The Average Overlay of the urbanization attribute.
The Average Overlay is a multi purpose Grid Overlay which displays (smoothed) values. These values can originate from spatial features, such as buildings, terrains, areas and neighborhoods. Alternatively, the values can originate from another Grid Overlay.
Spatial Features
A parameter assigned to a grid-cell can be related to one or more types of features in the project map: Buildings, Addresses, Terrains, Areas, Neighborhoods and Net Lines. The way this value is selected depends on the Averaged Input Type and calculation parameters.
Interpolate NODATA
The Average overlay can also be configured to replace NO_DATA values with interpolated non NO_DATA values using surrounding cells within a specified distance.
The Average Overlay of the urbanization attribute and additional information in the hover panel.
When clicking on a specific location in the map of the Average Overlay, the hover panel gives additional information about the actual value in that specific grid cell.
Calculation
The Average Overlay works by first rasterizing input values. These values can be obtained from Vector data or a Grid Overlay.
Once rasterized, the configured result type determines the operation applied on these values.
Additional parameters define the operation range, the default value if none is rasterized, and the number of timeframes for attributes with multiple values.
Averaged Input Type
You can also configure in what way a value for this overlay will be rasterized.
Key
  • First: Selects the first value encountered among all considered Vector data types. See Rasterized Vector data for the order.
  • Min: Selects the minimum value among all considered Vector data types.
  • Max: Selects the maximum value among all considered Vector data types.
  • Single layer: Only Vector data of the configured Maplink (Average Overlay) is rasterized.
Grid
Use the values of another Grid Overlay when specified as input, instead of an Attribute. NO_DATA values of the referenced Overlay result in NO_DATA values in the grid. The Average Overlay inherits the number of timeframes from the Input Overlay. If their grid sizes differ, the input grid is automatically resized.
Average Result Type
The configured Average Overlay result type determines how a cell's value is calculated. The following result types are supported for the Average Overlay:
Rasterized vector data depends on the Maplink (Average Overlay) and Average Input Type. If the input type is 'Grid', no vector data is used. Otherwise, all MapLink layers are considered if MapLink is null; otherwise, only the specified MapLink is rasterized.
The Average Overlay currently supports the following MapLinks (in order): Net Lines, Addresses, Buildings, Terrains, Areas, Neighborhoods.
Calculation
The way of averaging is defined by several Attributes, and can most easily be set using the Average Overlay Wizard.
The calculation can be configured via the following attributes:
