Project map
The project details showing the Map size and the Location (World reference Point) of a project
The project map is the rectangular data space of your project. It is defined by a width and a height. Its location is defined by a world reference point, which is a coordinate relative to the EPSG:3857 WGS 84 / Pseudo-Mercator coordinate system.
The width and height are stored in the MAP_SIZE_M Setting item as an array of two integers. The world reference point is stored in the WORLD_REFERENCE_POINT Setting item as an array of two Doubles, representing X and Y.
Generated projects and newly imported or drawn features must intersect with the project map; only the intersecting portions are imported. This holds for practically all items, with the exception of Height Sectors and Terrains.
Surrounding Map Bounds
The project map (red) and its surrounding map (satellite). Notice the satellite images and their corresponding height sectors and several water bodies as terrains.
Zooming out reveals a region surrounding the project map containing satellite images, height sector information, and terrain data. This provides better orientation and a visually cleaner project boundary.
The surrounding map extent is stored as a Setting, SURROUNDING_MAP_EXTEND_M, which defines the extra boundary distances around the project map. Its total dimensions are calculated as: xs=dx2+xmys=dy2+ym
xs and ys are the dimensions of the surrounding map extents.
dx and dy are the configured distances around the project map, stored in the setting SURROUNDING_MAP_EXTEND_M.
xm and ym are the project map dimensions, stored in the setting MAP_SIZE_M.
