Pump formula (Water Overlay)
Pumps are hydraulic structures that can pump water from one location to another.
Pumps move water from an area with a lower water level to one with a higher level.. If no (differing) water levels are defined, the surface height is used instead. The direction is determined during the initialization phase of the hydrological model, and does not change during the calculation even when water levels change.
A negative pump speed causes the pump to "drain" water in the opposite direction.
The amount being pumped or drained is dependent on the water levels on both sides of the pump.
Case 1: Pumping:
First the flow capacities are calculated.
If a positive Pump q is defined:
Qp,t=Δt⋅qt
If a lower threshold Tl,t is defined as well:
Ql,t=min(0,wl,t−Tl,t)
If an upper threshold T_{u,t} is defined as well:
Qu,t=max(0,Tu,t−wt,u)
If a capacity Qtotal is defined:
Qc=Qtotal−∑0..t−1Qi
After calculating the capacities, the actual water pumped upwards is calculated. If any of the terms are undefined, they are not included.
Δw=max(0,min(Ql,t,Qu,t,Qp,t,Qc))A
Case 2: Draining:
If a negative Pump q is defined:
Qp,t=Δt⋅qt
Ql,t=max(0,wl,t−Tl,t)
If an upper threshold Tu,t is defined as well:
Qu,t=min(0,Tu,t−wt,u)
Qc=Qtotal−abs(∑0..t−1Qi)
After calculating the capacities, the actual water drained (pumped downwards) is calculated. If any of the terms are undefined, they are not included.
Δw=min(0,max(Ql,t,Qu,t,Qp,t,−Qc))A
Where:
  • wl,t = The water level at the lower water level entry at time t, relative to datum.
  • wt,u = The water level at the upper water level entry at time t, relative to datum.
  • Tl,t = The LOWER_THRESHOLD of the pump at time t.
  • Tu,t = The UPPER_THRESHOLD of the pump at time t.
  • qt = The PUMP_Q of the pump at time t.
  • Qtotal = The pump capacity, defined in INLET_CAPACITY of the pump.
  • Q0..n = The calculated previous amounts of flow.
  • Ql,t = The desired amount of water at the entry based on the pump's LOWER_THRESHOLD attribute.
  • Qu,t = The desired amount of water at the exit based on the pump's UPPER_THRESHOLD attribute.
  • Qt = The PUMP_Q at time t for timestep Δt, which is the amount of water the pump can possibly pump (or drain, when negative).
  • Qc = The maximum amount of water flow based on the total capacity of the pump.
  • A = Size of the entry/exit area in m2, based on the amount of cells and cell size. Current implementation only has one cell.
Structures
Pump
Models
Surface model
