Breach (Water Overlay)
Revision as of 13:55, 15 July 2026 by Frank@tygron.nl (talk | contribs)
A Breach area can be used to simulate a breach in a levee or dam. It is identified via the BREACH_HEIGHT attribute. Water flowing through the breach originates from a body of water. This body of water can be defined as an input area in the project or a conceptual external water body existing outside the project area. Water can flow through the breach from the input water body to the defined Breach area, and vice versa.
Overlay attributes
