Sewer pump speed (Water Overlay)
Icon | Key | Unit | Description | Default value |
SEWER_PUMP_SPEED | m3/s | The amount of water removed from the sewer per second, by pumping it to an external area outside the project. | 0 |
This attribute can be defined as values over time, using an array of values defining start-time. This allows users to more dynamically define how fast water is removed from the model.
- Water pumped out of a sewer cannot be pumped back once it is in the external area.
- The sewer pump speed may never be negative, as this would conceptually result in water being pumped into the sewer from outside the project area.
- When using a dynamic SEWER_PUMP_SPEED, a maximum of 10.000 values (5.000 pairs) can be defined.
