External area (Water Overlay)
External water body as a trapezoid
  • If two values are provided, they represent the surface area and bottom area of the external water body, respectively. The water body will be interpreted as a trapezoidal prism, with a length set to the square root of the surface area. This will cause the water level of the external water body to change at a non linear rate.
  • When a breach input area is defined, an external water body will not be created. Subsequently, the EXTERNAL_SURFACE_LEVEL, EXTERNAL_WATER_LEVEL and EXTERNAL_AREA attributes will be ignored.
API Endpoints
