How to add a breach with external area manually
When setting up a breach for a Flooding Overlay, the intent is for water to flow through it. That water must come from a defined source. It is possible to manually define the location of the breach, and configure it with an external source of water. This means the water is not present in the Project map as is, but would be a virtual source linked to the breach, from which water is allowed to appear in the location of the breach and can flow across the terrain.
For more information on this topic, see: Breach model (Water Overlay)
How to add a breach with an external area to a Flooding Overlay manually:
- Add a new Area to the project. This will be the Breach Area.
- Draw the breach area in the 3D Visualization, in the location where the water from the breach should emerge (see tips below in gallery).
- Add an Attribute to the created Area, with the Breach Height attribute name and a height value.
- Open the Flooding Overlay wizard.
- Continue to the step concerning Breaches.
- Set the value for External Water Level.
- In case the volume of water in the External Area is limited, configure the External Area and External Surface Level.
- The configuration wizard of the Flooding Overlay can now be closed.
The breach drawn across the inner side of the levee.
Select the external option in the wizard and fill in the external water level, surface level and area.
- It is best to draw the Breach Area not too close to the water body and on the inside of the Levee /Dike ring that is going to inundate.
- It is only possible to create a Breach with an external area for the Flooding overlay.
- For an example of the External Breach Area, take a look at the Testbed Water Module project available in all domains.
- Breach (Water Overlay)
- How to add a breach with input area manually
- How to add a breach level area to a breach
