Aquifer (Water Overlay)
This functionality is currently in BETA.
Read more about Beta features.
The aquifer is an additional definition for the ground, allowing for ground horizontal flow different from the ground terrain's HYDRAULIC_CONDUCTIVITY_MD.
AQUIFER_KD | m²/day | The aquifer's hydraulic conductivity (with thickness), determining the speed of horizontal water flow underground. | n/a | |
AQUIFER_DATUM | m + datum | The datum height at which the aquifer layer is situated. | n/a |
- The aquifer only functions if its hydraulic conductivity is greater than 0. If it is 0 or less the aquifer is disregarded, and the regular ground flow formula using the ground terrain's hydraulic conductivity is applied.
- The aquifer functionality is also used to model drainages.
- Overlapping Aquifers are not allowed. Should in any location two or more Aquifers overlap, the values of one of them is used, and the values of the others are ignored.
