Api session event logic
Api session event logic Endpoints.
API EndPoints for EndPoints changing Functionality in a testrun/impact Session.
Name Description
action_log_export Export history of Actions taken by participants.
action_menu_set_function_available Add or remove a Function from a particular Action Menu.
action_menu_set_measure_available Add or remove a Measure from a particular Action Menu.
action_menu_set_upgrade_available Add or remove an upgrade from a particular Action Menu.
area_set_active Activate/deactivate a Area.
area_set_attribute Set Area Attribute to given number Value.
areas_set_attributes Per entry in the array, set the value of the Attribute for the Area.
building_set_attribute Set Building Attribute to given number Value.
building_set_attributes Per entry in the array, set the values of the Attribute for the Building.
cinematic_reached_point FlightPoint reached for a specific Cinematic.
cinematic_stakeholder_start Start a Cinematic for a specific Stakeholder.
cinematic_stakeholder_stop Stop any Cinematic for a specific Stakeholder.
dismiss_error Dismiss Error Log.
global_set_value Set Global Variable to given number Value.
global_set_values Set Global Variable to given number Values.
map_direct_sell_land Direct sale of land, no approval asked.
measurement_item_add Add a ItemMeasurement for an Overlay.
measurement_line_add Add a LineMeasurement for an Overlay for a specific Timeframe.
measurement_point_add Add a PointMeasurement for an Overlay.
measurement_remove Remove a Measurement.
measurement_save Save a Measurement.
measurement_set_overlays Set base Overlays for an existing Measurement.
measurement_set_sum Set a Measurement to add its base Overlays to itself.
money_transfer_add Create a new Money Transfer between two Stakeholders.
money_transfers_set_approved Approve a Money Transfer
neighborhood_set_attribute Set an Attribute for a Neighborhood.
net_cluster_set_fraction_connected Set the frAction of connected loads with a cluster.
net_cluster_set_load_attribute For each Net Load of a Net Cluster, set the value of the Attribute.
net_cluster_set_load_attributes For each Net Load of a Net Cluster, set the values of the provided Attributes.
net_clusters_set_default_fraction_connected Set the default frAction of connected loads with a cluster.
net_clusters_set_load_attributes Per Net Cluster, for each Net Load of that Net Cluster, set the values of the provided Attributes.
net_clusters_set_state Per Net Cluster, set all its Net Loads of the provided Net Type to the given Timestate.
net_line_set_attribute Set the Attribute of a Net Line to the provided value.
net_lines_set_attribute For each Net Line, set the value of the Attribute.
net_lines_set_attributes Per entry in the array, set the value of the Attribute for the Net Line.
scenario_set_active Activate a level.
scenario_set_attribute Set Scenario Attribute to given number Value.
search Search for Neighborhood, Building or Address.
session_release Release a client from a Session using its client token.
set_net_setting_boolean For boolean valued Net Settings (ELECTRICITY_ACTIVE, GAS_ACTIVE, HEAT_ACTIVE, INTERNET_ACTIVE, SEWER_ACTIVE, REQUIRE_UTILITY_CORPORATION_APPROVAL, CLUSTER_MODELS_ENABLED, LOAD_TO_NODE_LINES_ENABLED, FIRST_CONNECT_ACCEPT, RESTRICT_TO_NET_Overlay), set the value to true or false.
set_traffic_multiplier Multiply visual (only) traffic density with this factor.
special_effect_set_active Activate/deactivate a Special Effect.
stakeholder_release Release a Stakeholder from a Session.
stakeholder_select Select Stakeholder with preferred ID, when not available fallback to next best.
undo_last_building_action Undo the last Building Action of a Stakeholder.
unit_type_set_active Activate/deactivate units of a specific type.
zone_set_attribute Set an Attribute for a Zone.
zones_set_attributes Set Attributes to values for Zones.
