Api session event logic global set value
API Endpoint: api/session/event/logic/global_set_value/
Description: Set the Global to the specified value
| 0 | REQUIRED | (GLOBAL Integer ID or multiple integer values in array [1, 2, 3]) | Globals | |
| 1 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Value Array |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/global_set_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1.0 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/global_set_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1.0, 2.0, 3.0 ] ]'JavaScript example POST
body: '[ 1, 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/logic/global_set_value/", options)
