Api session event logic measurement point add
API Endpoint: api/session/event/logic/measurement_point_add/
Description: Add a Point Measurement for an Overlay
| 0 | REQUIRED | (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) | Overlays | |
| 1 | REQUIRED | (Point with crs: EPSG:3857) | Point | |
| 2 | REQUIRED | (String) | Name | |
| 3 | REQUIRED | (true, false) | Save Measurement | true or false |
| 4 | REQUIRED | (true, false) | Sum | true or false |
| 200 | Integer (Measurement) |
curl 'https://engine.tygron.com/api/session/event/logic/measurement_point_add/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658757.1265774464, 6799404.207347875 ]
}, "Name", true, true ]
'Curl example multi item POST
[ [ 1, 2, 3 ], {
"type" : "Point",
"coordinates" : [ 658744.3283850269, 6799313.136701938 ]
'JavaScript example POST
body: '[ 1, { "type" : "Point", "coordinates" : [ 658757.1265774464, 6799404.207347875 ]}, "Name", true, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/measurement_point_add/?crs=3857", options)
