Api session event logic net lines set attribute
API Endpoint: api/session/event/logic/net_lines_set_attribute/
Description: For each Net Line, set the value of the Attribute
| 0 | REQUIRED | (NET_LINE Integer ID or multiple integer values in array [1, 2, 3]) | Net Lines | |
| 1 | REQUIRED | (String) | Attribute | |
| 2 | REQUIRED | (Floating point number) | Value |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/net_lines_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute", 74 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/net_lines_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], "Attribute", 43 ]'JavaScript example POST
body: '[ 1, "Attribute", 74 ]'
fetch("https://engine.tygron.com/api/session/event/logic/net_lines_set_attribute/", options)
