Api session event logic stakeholder release
API Endpoint: api/session/event/logic/stakeholder_release/
Description: Release a Stakeholder from a Session
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/stakeholder_release/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/logic/stakeholder_release/", options)
