Api session event logic measurement line add
API Endpoint: api/session/event/logic/measurement_line_add/
Description: Add a Line Measurement for an Overlay for a specific Timeframe
0 REQUIRED (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) Overlays
1 REQUIRED (Point with crs: EPSG:3857) Point start
2 REQUIRED (Point with crs: EPSG:3857) Point end
3 REQUIRED (String) Name
4 REQUIRED (Integer number) Timeframe (-1 for automatic last)
5 REQUIRED (true, false) Save Measurement true or false
6 REQUIRED (true, false) Sum true or false
200 Integer (Measurement)
curl 'https://engine.tygron.com/api/session/event/logic/measurement_line_add/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658670.1670827096, 6799446.964162878 ]
 "type" : "Point",
 "coordinates" : [ 658778.2338501221, 6799347.621423313 ]
}, "Name", -1, true, true ]
Curl example multi item POST
[ [ 1, 2, 3 ], {
 "type" : "Point",
 "coordinates" : [ 658689.0054372621, 6799359.701586045 ]
 "type" : "Point",
 "coordinates" : [ 658763.5435391532, 6799311.913750029 ]
JavaScript example POST
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658670.1670827096, 6799446.964162878 ]}, { "type" : "Point", "coordinates" : [ 658778.2338501221, 6799347.621423313 ]}, "Name", -1, true, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/measurement_line_add/?crs=3857", options)
