Api session event logic cinematic reached point
API Endpoint: api/session/event/logic/cinematic_reached_point/
Description: Notify a Key Point is reached for a Cinematic
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 1 | REQUIRED | (CINEMATIC_DATA Integer ID) | Cinematic Data | |
| 2 | REQUIRED | (Integer number) | Key Point ID |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/cinematic_reached_point/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'JavaScript example POST
body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/logic/cinematic_reached_point/", options)
