Api session event logic net line set attribute
API Endpoint: api/session/event/logic/net_line_set_attribute/
Description: Set the Attribute of a Net Line to a value
| 0 | REQUIRED | (NET_LINE Integer ID) | Net Line | |
| 1 | REQUIRED | (String) | Attribute | |
| 2 | REQUIRED | (Floating point number) | Value |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/net_line_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute", 9 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/net_line_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute", 34 ]'JavaScript example POST
body: '[ 1, "Attribute", 9 ]'
fetch("https://engine.tygron.com/api/session/event/logic/net_line_set_attribute/", options)
