Api session event logic net lines set attributes
API Endpoint: api/session/event/logic/net_lines_set_attributes/
Description: Per entry in the array, set the value of the Attribute for the Net Line
0 REQUIRED (NET_LINE Integer ID or multiple integer values in array [1, 2, 3]) Net Lines
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attributes
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Values
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/net_lines_set_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute 1", 1.0 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/net_lines_set_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Attribute 1", "Attribute 2", "Attribute 3" ], [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST
 body: '[ 1, "Attribute 1", 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/logic/net_lines_set_attributes/", options)
