Api session event logic measurement item add
API Endpoint: api/session/event/logic/measurement_item_add/
Description: Add an Item Measurement for an Overlay
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay | |
| 1 | REQUIRED | (Enumeration) | Item Maplink | ACTION_LOGS, ACTION_MENUS, ADDRESSES, AREAS, ATTRIBUTE_ACTIONS, BUILDINGS, CHAT_CHANNELS, CHAT_MESSAGES, CINEMATIC_DATAS, CLIENT_WORDS, COSTS, CUSTOM_GEOMETRIES, DEFAULT_WORDS, ERROR_LOGS, EVENT_BUNDLES, EXCEL_SHEETS, FUNCTION_OVERRIDES, FUNCTIONS, GEO_LINKS, GEO_OPTIONS, GEO_PLUGINS, GEO_TIFFS, GLOBALS, HEIGHTS, INCOMES, INDICATORS, LEVEES, MEASUREMENTS, MEASURES, MODEL_DATAS, MODEL_SETS, MONEY_TRANSFERS, NEIGHBORHOODS, NET_CLUSTERS, NET_FUNCTIONS, NET_LINES, NET_LOADS, NET_NODES, NET_SETTINGS, NEURAL_NETWORKS, OVERLAYS, PANELS, PARAMETRIC_DESIGNS, PARAMETRIC_EXAMPLES, PARTICLE_EMITTERS, PLOTS, POPUPS, PROGRESS, PROJECT_ASSETS, RECORDINGS, SCENARIOS, SERVER_WORDS, SETTINGS, SKILLS, SOUNDS, SOURCES, SPECIAL_EFFECTS, SPECIAL_OPTIONS, STAKEHOLDERS, TERRAIN_TYPE_OVERRIDES, TERRAIN_TYPES, TERRAINS, TEXTURES, TIMES, TRIGGERS, UNIT_DATA_OVERRIDES, UNIT_DATAS, UPGRADE_TYPES, WATER_VALUES, WEATHERS, ZIP_CODES or ZONES |
| 2 | REQUIRED | (Integer number) | Item ID | |
| 3 | REQUIRED | (String) | Identifying Key | |
| 4 | REQUIRED | (String) | Name | |
| 5 | REQUIRED | (true, false) | Save Measurement | true or false |
| 200 | Integer (Measurement) |
curl 'https://engine.tygron.com/api/session/event/logic/measurement_item_add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "SETTINGS", 1, "Identifying Key", "Item measurement", true ]'JavaScript example POST
body: '[ 1, "SETTINGS", 1, "Identifying Key", "Item measurement", true ]'
fetch("https://engine.tygron.com/api/session/event/logic/measurement_item_add/", options)
