Api session event logic cinematic stakeholder stop
API Endpoint: api/session/event/logic/cinematic_stakeholder_stop/
Description: Stop a playing Cinematic for a Stakeholder
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/cinematic_stakeholder_stop/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/logic/cinematic_stakeholder_stop/", options)
