Api session event logic net clusters set default fraction connected
API Endpoint: api/session/event/logic/net_clusters_set_default_fraction_connected/
Description: Set the default fraction of connected loads with a cluster
| 0 | REQUIRED | (Floating point number) | Fraction connected, between 0 and 1 |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/net_clusters_set_default_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '39'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/net_clusters_set_default_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '65'JavaScript example POST
body: '39'
fetch("https://engine.tygron.com/api/session/event/logic/net_clusters_set_default_fraction_connected/", options)
