Api session event logic special effect set active
API Endpoint: api/session/event/logic/special_effect_set_active/
Description: Activate/deactivate a Special Effect
| 0 | REQUIRED | (SPECIAL_EFFECT Integer ID) | Special Effect | |
| 1 | REQUIRED | (true, false) | Activate | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/special_effect_set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'JavaScript example POST
body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/special_effect_set_active/", options)
