Inlet (Water Overlay)
(Redirected from Engine Link Rainfall Overlay Wizard/SYSTEM INLET)
Inlets are hydraulic structures that can pump water in to the hydrological model, or out of, in which case they function as Outlets. It will add or remove water at a defined maximum rate, with optional thresholds for the amount of water to add or remove.
An Inlet is by default a point-based building, but can optionally be an area-based building.
INLET_Q | m3/sec | -3.4028235E38 to 3.4028235E38 | The maximum amount of water flowing into the model through this Inlet. A negative value means the building functions as an outlet, and water is removed from the hydrological model. | 0 |
INLET_AREA | boolean | When true the Inlet is spread across the entire building surface. | 0 | |
INLET_CAPACITY | m3 | 0 to 3.4028235E38 | The maximum amount of water which can flow in or out through this Building. Water flowing back in the other direction replenishes the capacity. | 0 |
LOWER_THRESHOLD | m + datum | -10000 to 10000 | If a lower threshold is set, water will only flow into the model through this inlet until the water level at the point of this Inlet is equal to or greater than the threshold. If the threshold is not set, the amount of water flowing in is not limited in this fashion. | None |
UPPER_THRESHOLD | m + datum | -10000 to 10000 | If an upper threshold is set, water will only flow out of the model through this inlet until the water level at the point of this Inlet is equal to or less than the threshold. If the threshold is not set, the amount of water flowing out is not limited in this fashion. | None |
UNDERGROUND | boolean | 0 to 1 | When true the Inlet is connected to the groundwater. | false |
- Most Inlet attributes function as a limit to the flow. If multiple are defined, the flow is limited by the strongest limit. If neither an INLET_Q or any threshold is defined, there will be no flow.
- A negative INLET_Q changes the Inlet to an Outlet.
- The lower and upper thresholds define the range of valid water levels. If the actual water level does not fall in the specified range, the Inlet will allow water to flow in or out (depending on the configuration) to correct the water level.
- Unlike a Pump, which has two internal endpoints (or areas), an Inlet connects one internal endpoint to a conceptual external area with its own size and water level.
- How to correct inlets on land
- How to use outlets to remove water on the edges of your project
- How to correct multiple buildings on the same location
