Pump q (Water Overlay)
(Redirected from Engine Link Rainfall Overlay Wizard/PUMP Q)
PUMP_Q | m3/s | -3.4028235E38 to 3.4028235E38 | The flow rate at which water is pumped from the lower end-point to the higher end-point. | n/a |
This attribute can be defined as values over time, using an array of values defining start-time. This allows users to more dynamically define the maximum throughput and operational direction of the pump.
- The direction the pump pumps in can be reversed by configuring a negative PUMP_Q.
- When using a dynamic PUMP_Q, a maximum of 10.000 values (5.000 pairs) can be defined.
