Inlet (Water Overlay)
Revision as of 16:11, 11 November 2026 by Frank@tygron.nl (talk | contribs)
Inlets are hydraulic structures that can pump water in to the hydrological model, or out of, in which case they function as Outlets. It will add or remove water at a defined maximum rate, with optional thresholds for the amount of water to add or remove.
An Inlet is by default a point-based building, but can optionally be an area-based building.
Outlet
A negative INLET_Q changes the Inlet to an Outlet. It is advised to configure the Outlet as an area to ensure enough grid cells are available to extract water.
  • Most Inlet attributes function as a limit to the flow. If multiple are defined, the flow is limited by the strongest limit. If neither an INLET_Q or any threshold is defined, there will be no flow.
  • The lower and upper thresholds define the range of valid water levels. If the actual water level does not fall in the specified range, the Inlet will allow water to flow in or out (depending on the configuration) to correct the water level.
  • Unlike a Pump, which has two internal endpoints (or areas), an Inlet connects one internal endpoint to a conceptual external area with its own size and water level.
API Endpoints
